    Ok so i solved the FOR DCM problem.
    A wiring issue. 8)
    Now i need to find out how to control the 5 axis bob 0-10v output.
    m3 s1000 turns on relais
    m5 off.
    S1000 should set a voltage to output pin 1.. in pwm..
    Im not sure what pwm speed / frequency works with the bob
    1 khz?
    Also it looks like it is proportional but reversed.
    Anyone got a 5 axis 0-10volt working on uccnc?
    Or should i skip hardware I/O and go straight for modbus?
    Grtz Bert.
    Quote Originally Posted by driftspin View Post
    A wiring issue. 8)
    m5 off.
    1 khz?
    Grtz Bert.
    Ok solved the uccnc vs 5axis bob pwm/0-10volt programming.
    My UCCNC settings are:
    Pin 1 port 3. (im using port 3 for now)
    base frequency 800hz
    Looks frequency fixes linearity issues for me
    minimum dutycycle 100%.
    maximum dutycycle 0%.
    This fixed the reversed 0-10volt.
    Maybe Ill will adjust settings to make it work from 2-10volts later.
    so probebly 80 to 0 duty cycle
    I dont like the 0 volt level.
    It is almost linear now.
    Next is to get HY vfd to react to external 0-10v.
    Somehow the dial on the vfd is still active instead of external signal.
    Must have still missed something.
    Grtz Bert.
  1. BUILD LOG: First time build - Steel Frame CNC Router
    By examorph in forum DIY Router Build Logs
    Last Post: 19-10-2023, 06:25 PM
  2. BUILD LOG: First Build 5 x 12 Steel Frame CNC router
    By Scott Damman in forum DIY Router Build Logs
    Last Post: 18-01-2017, 06:36 PM
  3. BUILD LOG: Steel frame cnc router design/build
  4. 600x900 Steel welded router build
    By embraced in forum Gantry/Router Machines & Building
    Last Post: 08-10-2014, 10:55 PM
  5. BUILD LOG: First steel diy CNC router build
