Page 1 of 15 12311 ... LastLast
    Hi all, this is the first post of my build log.
    After reading a lot on this site i made some of the build decisions.
    Basically it is a half raised gantry router.
    Planning on 15mm alu toolingplate Z-Axis
    1st.. size.
    - 1500x 800 x 200 mm work area.
    2nd materials to be cut.
    - Wood and aluminium.
    3rd basic building material.
    - Steel box section. 120×80×4mm and 80x80x4mm
    Router type.
    - 4 bearing Chinese WC ER20 2..2kw
    VFD ...
    -Danfoss FC-51 type.
    linear stuff.
    - 20mm rail, c7 rolled ballscrew1610 for Y, 1605 for Z, 2010 for X
    - 4 x nema 23 3 or 4 NM type
    Or maybe 2 nema23 and 1 nema 34...
    Is undecided for now.
    Tools
    -I have no access to mill.
    -I have access to old lathe. but no real experience
    - Basic hand / power tools.
    - Design sw
    Solidworks.
    Cnc controls
    - Eyeballing uccnc300eth
    - Digital drivers 68v diy psu
    So that is the plan.
    I do notice i am refining the plan on the go.
    Hello!
    Sounds awsome :D
    Good luck and for ours sake post a lot of pictures..!
    Skickat från min SM-N910C via Tapatalk
    Hello!
    Sounds awsome :D
    Yes... pictures... ill try to post on every progress..
    Actually i started work on a design over a year ago.
    1st the plan was to make an adjustable bed.
    This over complicated the design.... or weakened it...
    now the design is more basic.
    Buying steel is not a problem.
    Getting 6mtr length box section cut or stored in my shed is..
    Shed is just 5.7m X 3.7m
    So i orderd the steel box section, and some end plates pre cut, ready to weld up.
    A friend of mine works with steel, he is my main supplier for steel related stuff.
    We share a hobby 150 Amp migwelder. (Cebora)
    It was bought for automotive related welding.
    This is what the start of my cnc hobby looked like in the back of my car
    I spirit levelled the top of a standard used desk for setting up the bed box section.
    Dont ask me why i did not start with the legs of the frame.
    Ok .... its gonna be bulky...
    Tag welding it up
    After final welding i found out warping will happen...
    Total distortion is now +/- 1.5 mm
    1850x1160 mm total size.
    I have read on this forum this could happen... But is was still more than i expected.
    Epoxy has to solve this problem in a later stage...
    More to come.
    linear stuff.
    - 20mm rail, c7 rolled ballscrew1610 for Y,Z, 2010 for X
    I would re think this for me I would use 1610 for X & Y and 1605 for Z
    With nema 23 3.1nM
    Have a look a Joe's build http://www.mycncuk.com/threads/4513-...ight=joeharris
    looks nice, I'd just be a little concerned about how you are going to make the rails work on the gantry? That orientation is going to be very tricky to align within the required tolerances on a steel beam. What was your plan in that regard?
    Quote Originally Posted by Zeeflyboy View Post
    Dear Zeeflyboy,
    I hope for a miracle by epoxy
    First one needs a zero reference for horizontal level.
    I think it was Boyan who explained on the forum he made a reference level surface for this on a concrete floor by pouring epoxy.
    I will try this way.
    I will spirit level and anker bolt my frame to the concrete floor before pourings so nothing can move and use the x poured epoxy rail mounting surface for this.
    Pouring the rail mounting surface for X will be done like the example from a forum member see picture.
    like the X axis the 4 mounting surfaces on the gantry will be epoxy levelled.
    In 2 steps...
    Step 1 I will do the 2 gantry X rail carriage mounting surfaces, and bottom Y rail mounting surface pouring, in 1 go. ( gantry upside down )
    There will be an epoxy levelling bridge between the 2 carriage mounting surfaces
    Similar to x rail pouring setup
    So now those 3 surfaces will be in the same plain.
    After curing..
    Step 2 The gantry can now be flipped to normal position and top Y axis rail mounting surface can be poured..
    Placing the gantry in the normal position on the mounting surface of the x rail should give the best possible reference for a level plain.
    After pouring Y bottom and top should be in the same plain..
    In theory this should work.
    I know this will be a critical process.
    When this method fails i will redesign and have the gantry (rail) mounting surfaces milled. nothing much changes only a few pounds of steel added.
    When milling is needed i will upgrade the gantry box section to 80x120x8 or 10 to have some meat to mill
    I do want to avoid **bolting** the gantry sides to the gantry Y-axis.
    I prefer welded solid for best rigidity.
    But welding solid must be avoided going that route, because of warping.
    I have no friends with a mill capable of box section 1200X120x80.
    Would a surface grinder work for this purpose?
    Any other thoughts?
    Thats how i did it on the gantry, my first build. gantry was flipped 180 degree and i poured gantry sides and lower beam epoxy. Then flipped and did upper rail. No problem.
    But you will need a straight edge and 2 precision squares for later when mounting the rails and so...
    Quote Originally Posted by driftspin View Post
    Dear Zeeflyboy,
    In 2 steps...
    After curing..
    Any other thoughts?
    Sounds good! Will watch with interest. Good luck!
  1. BUILD LOG: First time build - Steel Frame CNC Router
    By examorph in forum DIY Router Build Logs
    Last Post: 19-10-2023, 06:25 PM
  2. BUILD LOG: First Build 5 x 12 Steel Frame CNC router
    By Scott Damman in forum DIY Router Build Logs
    Last Post: 18-01-2017, 06:36 PM
  3. BUILD LOG: Steel frame cnc router design/build
  4. 600x900 Steel welded router build
    By embraced in forum Gantry/Router Machines & Building
    Last Post: 08-10-2014, 10:55 PM
  5. BUILD LOG: First steel diy CNC router build
