    8.8 means tensile strength of ~800 MPa and yield strength of ~80% of this
    12.9 means tensile strength of ~12 MPa and yield strength of ~90% of this
    So 12.9 will be much stronger than 8.8 but you are usually not interested in that. You are unlikely to create forces high enough to break the bolts on a diy machine. 8.8 MPa is quite a lot !
    What you are interested in is the stiffness of the bolts as this tells you how much deflection you will get when machining parts. But this will be similar in both bolt types so 8.8 will be fine. No harm in using 12.9 but they won't give you any benefit.
    If you are interested in why it is because the stress/strain curves have the same slope, it is just that the 12.9 bolts will go further along the curve as they are stronger.
    If you buy stainless there is a different naming system as stainless does not really yield before it breaks (by comparison) but again there is no diy CNC advantage other than looks nice and won't rust
  2. The Following 2 Users Say Thank You to routercnc For This Useful Post:
  3. #2
    Ok guys i'm clearly not into engineering like you all are
    Getting there... some day... maybe.
    ok welded in braces today..
    Now some more degreasing and set up for pouring.
    Will post soon.
    Looks good!
  5. #4
    Looks good!
    Update
    Last steps welding .
    Prepping stuff for pour.
    Idea is to use simpel floor board and silicone kit to leak proof..
  1. BUILD LOG: First time build - Steel Frame CNC Router
    By examorph in forum DIY Router Build Logs
    Last Post: 19-10-2023, 06:25 PM
  2. BUILD LOG: First Build 5 x 12 Steel Frame CNC router
    By Scott Damman in forum DIY Router Build Logs
    Last Post: 18-01-2017, 06:36 PM
  3. BUILD LOG: Steel frame cnc router design/build
  4. 600x900 Steel welded router build
    By embraced in forum Gantry/Router Machines & Building
    Last Post: 08-10-2014, 10:55 PM
  5. BUILD LOG: First steel diy CNC router build
