11-05-2018 #141
Hi Guys,
I would like some spindle buying advice.
What spindle is ok?
http://r.ebay.com/yiK93w
or
http://r.ebay.com/IqnGLI
or
http://r.ebay.com/VvZdsW
Looks like i want the taishi one?
Grtz Bert?Last edited by driftspin; 11-05-2018 at 08:00 PM.
11-05-2018 #142
In my opinion the bottom one is fine http://r.ebay.com/VvZdsW BUT always check the parameters in the vfd before you run it. As they are sometimes wrong.
12-05-2018 #143
Huan Yang VFD with Taishi spindle seems to be the best pack according the people at the forums.
No matter what spindle you decide to buy just make sure it has four bearings at Clive has suggested!
12-05-2018 #144
12-05-2018 #145
I didn't write it right so clearly for someone to understand I guess. :-)
I am referring to something that you have notice so many other time to others and to me also,about the four bearing spindle been better than those with three or two.
Of course the vfd must be set up before run mine came with wrong parameters also but the seller provide me with the data on email how to put the correct parameters on the vfd.
Sorry for the inconvenience!
12-05-2018 #146No its no problem Nick. Trouble is there are a couple of different VFD's that look the same but are completely different inside. You can tell by the front panel. Yes you are correct some time they have the wrong params. set.Sorry for the inconvenience!..Clive
The Following 2 Users Say Thank You to Clive S For This Useful Post:
13-05-2018 #147
Ok so i know what to order.
Thanks guys.
Grtz Bert.
15-05-2018 #148
So, i have been on a shopping spree.
Painfull process :-)
Unregulated psu 500va 68v
Vfd 2.2kw
spindle 2.2 kw
WC pump (12v dc pc style)
WC radiator 80mm (12v dc pc style)
Clamp 80mm
Collet set 6 pcs .. 2 4 6 8 10 12
uc300eth
2 very cheap 5 axis bob. for now. maybe ub1 later
drivers 4x dm856
5 proximity switches 6-36v NPN
pulleys
belts
5 junction boxes
20 or so glands
cy cable 4x1
6mm airline
some 10mm pvc coolant hose.
3m 15x50 dragchain
Stuff to buy:
2mm? allan key to lock the ballscrewnut in place.
Did you guys make a flat spot on the ballscrews for more grubscrew grip?
UCCNC
Any suggestions on the pc specs?
It will just be the cnc machine pc.
Cad software will run on separate machine. Nvidia graphics icm F360?
Router bits, I need suggestions on a starter kit :-) for these materials.
Aluminum,
mdf,
soft / hardwood.
And yes steel 8-), just for the sake of testing if it is capable. lets break some bits.
Grtz Bert.
16-05-2018 #149
I have no answers for you, just want to cheer you on ;)
Did you order from China or EU?
Just wondering about delivery times :)
16-05-2018 #150
Hi nr1madman,
Well eh only spindle/vfd is from a Germany warehouse. But still China.
Steppers from UK/ Still China i guess.
Belts from US i think.
Fastners nuts bolts and small tools, local home improvement (Hornbach) store and places like Toolstation.
Cant believe there is no profitable production /distribution possible anymore in Europe.
Ok.
Every thing else is from China directly.
Ebay, Aliexpress.
Some stuff like linear only took 1 week after "shipped" notice.. Carrier GLS.
Tax through invoice after delivery.
Most "free shipping" goods take 12- 15 working days.
Now my drives , bobs, spindle, vfd, 80mm bracket have not arrived yet... so.
I hope to finish fabricating soon.. that is... weeks.
After that wiring.
Grtz Bert.
There are currently 15 users browsing this thread. (0 members and 15 guests)
BUILD LOG: First Build 5 x 12 Steel Frame CNC router
By Scott Damman in forum DIY Router Build LogsReplies: 104Last Post: 18-01-2017, 06:36 PM -
600x900 Steel welded router build
By embraced in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 08-10-2014, 10:55 PM -
By ivars211 in forum DIY Router Build LogsReplies: 59Last Post: 28-07-2014, 08:29 PM
