Page 21 of 21 FirstFirst ... 11192021
  1. #201
    For F360 on YouTube, Lars Christensen is the best i think ;)
  2. #202
    Lives in Marple Stockport, United Kingdom. Last Activity: 10 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Plus one
  3. #203
    Plus one
    Yes he has been of great help so far.
    Youtube has lots of good instruction videos Lars makes it look easy.
    I was struggeling with loft cuts through multiple bodies.
    Solid works can cut through parts in an assembly. F360 doesn't like that and cuts through bodies.
    Need to find out how to do nesting.
    And use g54 and up.
    Can nesting be done in F360?
    I am very in efficient atm with the stock.
    But i am having fun more than anticipated :-)
    There is a question.
    Should a low end shopvac (i have a nilfisk buddy 12) do for a dust shoe?
    Want to try +/- 50mm id hose icw a cyclone with that vac.....
    It has a 25 mm id hose now.. it is kinda okay. Dust doesn't fly everywhere now...
    Nilfisk Buddy 12 is very noisy...
    Much more than the cnc is, most of the time.
    Tried to read up on vacuum cleaners air watts and all.
    Looks like a cheap shop vac is a dead end for multiple reasons.
    Ill name a few typical issues on cheap models.
    -Shorter life span.
    -Bad hepa reputation on most.
    -Not the highest volume.
    -Noisy.
    I am not clear on an economic and effective (hepa) solution.
    Can a diy solution compete with commercial dust removal systems?
    I was thinking a shop vac for cnc dust removal at the spindle
    ICW a diy high volume (recirculation) hepa air cleaner for the whole shop. based on a standard fan and maybe 3 or 4 standard 300x300x35mm filters to improve flow on a low pressure type fan i have lying arround.
    So high flow low power low noise.
    So what do you guys use?
    Grtz. Bert.
  4. #204
    Quote Originally Posted by driftspin View Post
    And use g54 and up.
    -Shorter life span.
    -Noisy.
    Grtz. Bert.
    I have a question about tranning.
    How did you guys setup tranning of the spindle ?
    Maybe set screws?
    Grtz Bert
  1. BUILD LOG: First time build - Steel Frame CNC Router
    By examorph in forum DIY Router Build Logs
    Last Post: 19-10-2023, 06:25 PM
  2. BUILD LOG: First Build 5 x 12 Steel Frame CNC router
    By Scott Damman in forum DIY Router Build Logs
    Last Post: 18-01-2017, 06:36 PM
  3. BUILD LOG: Steel frame cnc router design/build
  4. 600x900 Steel welded router build
    By embraced in forum Gantry/Router Machines & Building
    Last Post: 08-10-2014, 10:55 PM
  5. BUILD LOG: First steel diy CNC router build
