11-08-2017 #1
Hi all, this is the first post of my build log.
After reading a lot on this site i made some of the build decisions.
Basically it is a half raised gantry router.
Planning on 15mm alu toolingplate Z-Axis
1st.. size.
- 1500x 800 x 200 mm work area.
2nd materials to be cut.
- Wood and aluminium.
3rd basic building material.
- Steel box section. 120×80×4mm and 80x80x4mm
Router type.
- 4 bearing Chinese WC ER20 2..2kw
VFD ...
-Danfoss FC-51 type.
linear stuff.
- 20mm rail, c7 rolled ballscrew1610 for Y, 1605 for Z, 2010 for X
- 4 x nema 23 3 or 4 NM type
Or maybe 2 nema23 and 1 nema 34...
Is undecided for now.
Tools
-I have no access to mill.
-I have access to old lathe. but no real experience
- Basic hand / power tools.
- Design sw
Solidworks.
Cnc controls
- Eyeballing uccnc300eth
- Digital drivers 68v diy psu
So that is the plan.
I do notice i am refining the plan on the go.
Verstuurd vanaf mijn SM-A320FL met TapatalkLast edited by driftspin; 11-12-2017 at 12:19 AM.
11-08-2017 #2
Hello!
Sounds awsome :D
Good luck and for ours sake post a lot of pictures..!
11-08-2017 #3
11-08-2017 #4
Buying steel is not a problem.
Getting 6mtr length box section cut or stored in my shed is..
Shed is just 5.7m X 3.7m
So i orderd the steel box section, and some end plates pre cut, ready to weld up.
A friend of mine works with steel, he is my main supplier for steel related stuff.
We share a hobby 150 Amp migwelder. (Cebora)
It was bought for automotive related welding.
11-08-2017 #5
This is what the start of my cnc hobby looked like in the back of my car
I spirit levelled the top of a standard used desk for setting up the bed box section.
Dont ask me why i did not start with the legs of the frame.
Ok .... its gonna be bulky...
Tag welding it up
After final welding i found out warping will happen...
Total distortion is now +/- 1.5 mm
1850x1160 mm total size.
I have read on this forum this could happen... But is was still more than i expected.
Epoxy has to solve this problem in a later stage...
More to come.
Verstuurd vanaf mijn SM-A320FL met TapatalkLast edited by driftspin; 14-09-2017 at 07:11 PM.
11-08-2017 #6I would re think this for me I would use 1610 for X & Y and 1605 for Zlinear stuff.
- 20mm rail, c7 rolled ballscrew1610 for Y,Z, 2010 for X
With nema 23 3.1nM
Have a look a Joe's build http://www.mycncuk.com/threads/4513-...ight=joeharris..Clive
11-08-2017 #7
looks nice, I'd just be a little concerned about how you are going to make the rails work on the gantry? That orientation is going to be very tricky to align within the required tolerances on a steel beam. What was your plan in that regard?
11-08-2017 #8
Hi Clive,
I was playing around with the stepper calculator from this forum...
1605 on Z 1:1 ? or also reducted?
Picking the 2010 over a 1610 on x axis ,1700mm between bearings, is about critical rpm vs speed... looks like i need 2010 to reach up to or over 5 m/min.
What is your opinion on these?
Since i am a beginner i am not sure what the max speed is i would need for cutting and rappids
Some other materials might need faster speeds i am not sure...
2.2kw spindle makes cutting at lower rpm easier combined with a quality vfd.
I am trying to pick the right quality parts to make a versatile machine.
Any help is welcome.
Please share your concerns.
No linear parts or elektronics are bought yet.
11-08-2017 #9Yes I agree. Have you decided on one motor or two?Picking the 2010 over a 1610 on x axis ,1700mm between bearings, is about critical rpm vs speed... looks like i need 2010 to reach up to or over 5 m/min.
Don't buy any electrics until you have it all drawn up in CAD AM882 or EM806 work well for the drives at 68V..Clive
12-08-2017 #10
Dear Zeeflyboy,
I hope for a miracle by epoxy
First one needs a zero reference for horizontal level.
I think it was Boyan who explained on the forum he made a reference level surface for this on a concrete floor by pouring epoxy.
I will try this way.
I will spirit level and anker bolt my frame to the concrete floor before pourings so nothing can move and use the x poured epoxy rail mounting surface for this.
Pouring the rail mounting surface for X will be done like the example from a forum member see picture.
like the X axis the 4 mounting surfaces on the gantry will be epoxy levelled.
In 2 steps...
Step 1 I will do the 2 gantry X rail carriage mounting surfaces, and bottom Y rail mounting surface pouring, in 1 go. ( gantry upside down )
There will be an epoxy levelling bridge between the 2 carriage mounting surfaces
Similar to x rail pouring setup
So now those 3 surfaces will be in the same plain.
After curing..
Step 2 The gantry can now be flipped to normal position and top Y axis rail mounting surface can be poured..
Placing the gantry in the normal position on the mounting surface of the x rail should give the best possible reference for a level plain.
After pouring Y bottom and top should be in the same plain..
In theory
this should work.
I know this will be a critical process.
When this method fails i will redesign and have the gantry (rail) mounting surfaces milled. nothing much changes only a few pounds of steel added.
When milling is needed i will upgrade the gantry box section to 80x120x8 or 10 to have some meat to mill
I do want to avoid **bolting** the gantry sides to the gantry Y-axis.
I prefer welded solid for best rigidity.
But welding solid must be avoided going that route, because of warping.
I have no friends with a mill capable of box section 1200X120x80.
Would a surface grinder work for this purpose?
Any other thoughts?
BUILD LOG: First Build 5 x 12 Steel Frame CNC router
By Scott Damman in forum DIY Router Build LogsReplies: 104Last Post: 18-01-2017, 06:36 PM -
600x900 Steel welded router build
By embraced in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 08-10-2014, 10:55 PM -
By ivars211 in forum DIY Router Build LogsReplies: 59Last Post: 28-07-2014, 08:29 PM
