08-04-2018 #11
Hi all
I want to order some drag chain.
What did i forget..?
Things to put in the drag chain.
Ground wire 4mm2 6mm
Spindle cy 4x1.5 mm 9.6mm
y home switches cy 4x0.75 7.1mm
z home switches cy 4x0.75 7.1mm
y stepper cy 4x075 7.1mm
z stepper cy 4x0.75 7.1mm
Spindle coolingpump/fan cy 4x0.75 7.1mm
or
Supply / return line spindle cooling 2x 8mm
compressed air line 8mm
coolant line 8mm
Control valve air/mist/ coolant cy 4x0.75 7.1 mm, do you guys put that in the controls cabinet?
Miscelanious.. dustshoe retract.. power for camera, spindle illumination cy 4x0.75 7.1mm
Maybe combine all controls like valves, spindle light, mist/air, coolingpump / fan etc in 1 cable.
What did i forget?
Grtz Bert.
Verstuurd vanaf mijn SM-A320FL met TapatalkLast edited by driftspin; 08-04-2018 at 05:43 PM.
BUILD LOG: First Build 5 x 12 Steel Frame CNC router
By Scott Damman in forum DIY Router Build LogsReplies: 104Last Post: 18-01-2017, 06:36 PM -
600x900 Steel welded router build
By embraced in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 08-10-2014, 10:55 PM -
By ivars211 in forum DIY Router Build LogsReplies: 59Last Post: 28-07-2014, 08:29 PM
