27-05-2018 #10
Doddy thank you for your explanation.
Please verify if i understand you correctly and false or true the below.
1 -
Pulse, dir, enable, from uc to 5 axis bob is 5 volt level. based on 5volt supply circuit to bob/uc.
2-
External psu connection 12/24vdc to bob is for 0-10volt /pwm only.
3-
Estop / axis end switches.
I have 24vdc volt power supply which will be used to power the e-stop circuit / relais.
1 free contact on e-stop relais will connect to bob e-stop pin / bob gnd.
4-
Homing.
LJ8A3-2-Z/BX
These proximity switches are NPN.
Now because they run off a higher voltage separate psu i have to connect 5 volt ground to 24volt ground or they will not work icm with 5axis bob inputs.
This worries me a little since i thought the bob would be 24v on the inputs for homing
based on the applied external psu.
I have read on this forum 24v signals are preferred for interference reasons.
5-
I read your warning about the opto isolation, this worries me to.
Having a € 175,- motion controller i.c.m. with a € 5,- bob that does not protect the controller... does not make sense.
Please comment on the above.
Grtz. Bert.
BUILD LOG: First Build 5 x 12 Steel Frame CNC router
By Scott Damman in forum DIY Router Build LogsReplies: 104Last Post: 18-01-2017, 06:36 PM -
600x900 Steel welded router build
By embraced in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 08-10-2014, 10:55 PM -
By ivars211 in forum DIY Router Build LogsReplies: 59Last Post: 28-07-2014, 08:29 PM
