  1. #14
    Quote Originally Posted by driftspin View Post
    HI guys,
    for a 2.2 kw spindle.
    What size bit can i use to level my wooden bed surface?
    Grtz Bert
    I have a 1.5kW spindle and used an 18mm 2 flute router bit to skim a wooden bed without a problems. You could probably go larger - there is a larger bottom cutting type bit which others have used.
  2. The Following User Says Thank You to routercnc For This Useful Post:
  1. BUILD LOG: First time build - Steel Frame CNC Router
    By examorph in forum DIY Router Build Logs
    Last Post: 19-10-2023, 06:25 PM
  2. BUILD LOG: First Build 5 x 12 Steel Frame CNC router
    By Scott Damman in forum DIY Router Build Logs
    Last Post: 18-01-2017, 06:36 PM
  3. BUILD LOG: Steel frame cnc router design/build
  4. 600x900 Steel welded router build
    By embraced in forum Gantry/Router Machines & Building
    Last Post: 08-10-2014, 10:55 PM
  5. BUILD LOG: First steel diy CNC router build
