29-10-2017 #9
Hi Nr1madman....
More knowledge? No.
The witdh of the profile is about 80 mm.
The witdh at 5 mm epoxy thickness should be about 70mm, plenty of room for some meniscus and enough flat surface left for mounting the rail.
I want to see what te result will be on the bottom of the gantry x mounting surface.
I might decide i want the wide type carriages on x because there is space enough for them there.. miniscus might become a problem there..
Any thoughts?
BUILD LOG: First Build 5 x 12 Steel Frame CNC router
By Scott Damman in forum DIY Router Build LogsReplies: 104Last Post: 18-01-2017, 06:36 PM -
600x900 Steel welded router build
By embraced in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 08-10-2014, 10:55 PM -
By ivars211 in forum DIY Router Build LogsReplies: 59Last Post: 28-07-2014, 08:29 PM
