12-11-2017 #10
Well actually... i just poured the x- rail mounting sufaces 2x 320mmx80mm x5mm + the connecting bridge 1000mmx40mmx5mm
Total about 0.5 liters ~ 0.5kg
I have just checked.. temperature is steady at 22 deg C. Epoxy is only just starting to get solid... it is just getting real sticky now. 16hrs after pour.
The leaking epoxy was used the coat the kit seams for the big pour: bottom rail Y surface+ 2x rail x surface and bridge.
i used a small paintbrush to soak the seams and connections
about 5mx80mmx5mm of channel to fill and a 1mx40x5mm to fill.
The flow thickness of epoxy when you just start the pour is about 3 or 4 mm thick.
So yes i agree pour the whole thickness in 1 go.
I have a good feeling about keeping the temperature steady.
In the test pour there was orange skin like surface finish... no sign of that , well not jet.
The big pour i did today : shiny surfaces.
I mixed 1kg first.. then another 0.5kg.
looks like after allowing the epoxy to flow for a few hours i can see the frame straightness is good to within 2mm
Epoxy film thickness varies from +/- 6 to 4 mm
... some leaks not to bad... easy fix.
Now i need to wait a week before i can flip the gantry, clean up, and pour the last surface top y axis rail mounting surface.
Grtz.
Bert.
BUILD LOG: First Build 5 x 12 Steel Frame CNC router
By Scott Damman in forum DIY Router Build LogsReplies: 104Last Post: 18-01-2017, 06:36 PM -
600x900 Steel welded router build
By embraced in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 08-10-2014, 10:55 PM -
By ivars211 in forum DIY Router Build LogsReplies: 59Last Post: 28-07-2014, 08:29 PM
