24-03-2018 #9
Decided and ordered.
Its gonna be 4 steppers
4x 4amp 4Nm nema23 All round : cnc4you
Does anybody have a realistic number on power needed for those?
I would like to do a dual diy toroidal transformer setup.
So 2 dual 24v transformers , dual rectifier.
dual 68volt circuit.
1 for dual x motors and
1 for the y and z motor.
Is it as simple as 2x4 Amp stepper, so 8 to 10 Amp 400 to 500VA per transformer?
Or will less power be sufficient?
1 kW sounds like a lot and ott.
I gues not many times all 4 steppers are running full throttle all the time...
Anyone?
Grtz Bert.
Also ... is there such a thing as minimum belt length?
BUILD LOG: First Build 5 x 12 Steel Frame CNC router
By Scott Damman in forum DIY Router Build LogsReplies: 104Last Post: 18-01-2017, 06:36 PM -
600x900 Steel welded router build
By embraced in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 08-10-2014, 10:55 PM -
By ivars211 in forum DIY Router Build LogsReplies: 59Last Post: 28-07-2014, 08:29 PM
