  1. #9
    Hello again!
    Doesnt matter if you have dual 115 primaries or a single 230v. You can connect 2x115 in series to get 1x230 :)
    Same with the secondaries.. you can look for 2x24v or 1x48 or 2x48v .. same thing for your application!
    You might have an easier time finding the right stuff from rs online, just a tip
    For example : https://uk.rs-online.com/mobile/p/to...rmers/1176071/
  2. The Following User Says Thank You to Nr1madman For This Useful Post:
  1. BUILD LOG: First time build - Steel Frame CNC Router
    By examorph in forum DIY Router Build Logs
    Last Post: 19-10-2023, 06:25 PM
  2. BUILD LOG: First Build 5 x 12 Steel Frame CNC router
    By Scott Damman in forum DIY Router Build Logs
    Last Post: 18-01-2017, 06:36 PM
  3. BUILD LOG: Steel frame cnc router design/build
  4. 600x900 Steel welded router build
    By embraced in forum Gantry/Router Machines & Building
    Last Post: 08-10-2014, 10:55 PM
  5. BUILD LOG: First steel diy CNC router build
