  1. #10
    Theory : uh was it like ....
    (25+25)*sqrt 2 / 230v*235v?? = 72,2 volts
    (24+24)*sqrt 2 / 230v*235v?? = 69.4 volts
    Goal : 68volts DC
    Well, rectifier steals maybe 1 volt (Vf =1.1 volt) ?
    Can you please confirm? 24+24 is harder to find.
    Ok I am not a math person but I think you might be doing this the wrong way.
    25-25 = 50 x 1.414 = 70.07 - rectifier 2 x 1.1 v = 68.5v
    Single or double primary no difference, dual primary are easier to find. You won't have any trouble with 25-25 or 24-24 v sec.
    Don't forget you are measuring V without load. You also said you have a 25Mtr run
    Sorry about the links the forum shortened them.
  2. The Following 2 Users Say Thank You to Clive S For This Useful Post:
  1. BUILD LOG: First time build - Steel Frame CNC Router
    By examorph in forum DIY Router Build Logs
    Last Post: 19-10-2023, 06:25 PM
  2. BUILD LOG: First Build 5 x 12 Steel Frame CNC router
    By Scott Damman in forum DIY Router Build Logs
    Last Post: 18-01-2017, 06:36 PM
  3. BUILD LOG: Steel frame cnc router design/build
  4. 600x900 Steel welded router build
    By embraced in forum Gantry/Router Machines & Building
    Last Post: 08-10-2014, 10:55 PM
  5. BUILD LOG: First steel diy CNC router build
