  1. #10
    Bert can you post a pic with the old seals and with the new ones on the bearings?
    Hi Nickhofen,
    I can post the before.
    I can make a few pictures of the after later today.
    Seal vs ring.
    Look at the gap between the seal and ring.
    And the opened bearingblock.
    No seal in the bearing.
    Fred explained there was change in his inventorie... sealed and non sealed bearings. And a customer that did not want the bearing block seals to touch the rings because of the resistance this has.
    This was a big customer and he had left over stock.
    Grtz Bert
    The last picture shows the old seal icw rings from 20mm ballscrew.
    And the ring in the bearingblock with a new seal
  2. The Following User Says Thank You to driftspin For This Useful Post:
  1. BUILD LOG: First time build - Steel Frame CNC Router
    By examorph in forum DIY Router Build Logs
    Last Post: 19-10-2023, 06:25 PM
  2. BUILD LOG: First Build 5 x 12 Steel Frame CNC router
    By Scott Damman in forum DIY Router Build Logs
    Last Post: 18-01-2017, 06:36 PM
  3. BUILD LOG: Steel frame cnc router design/build
  4. 600x900 Steel welded router build
    By embraced in forum Gantry/Router Machines & Building
    Last Post: 08-10-2014, 10:55 PM
  5. BUILD LOG: First steel diy CNC router build
