Page 15 of 21 FirstFirst ... 51314151617 ... LastLast
  1. #141
    Hi Guys,
    I would like some spindle buying advice.
    What spindle is ok?
    http://r.ebay.com/yiK93w
    or
    http://r.ebay.com/IqnGLI
    or
    http://r.ebay.com/VvZdsW
    Looks like i want the taishi one?
    Grtz Bert?
  2. #142
    Lives in Marple Stockport, United Kingdom. Last Activity: 13 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,342. Received thanks 618 times, giving thanks to others 82 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by driftspin View Post
    Hi Guys,
    What spindle is ok?
    or
    or
    Grtz Bert?
    In my opinion the bottom one is fine http://r.ebay.com/VvZdsW BUT always check the parameters in the vfd before you run it. As they are sometimes wrong.
  3. #143
    Huan Yang VFD with Taishi spindle seems to be the best pack according the people at the forums.
    No matter what spindle you decide to buy just make sure it has four bearings at Clive has suggested!
  4. #144
    Its the vfd that needs to be the correct one.
  5. #145
    I didn't write it right so clearly for someone to understand I guess. :-)
    I am referring to something that you have notice so many other time to others and to me also,about the four bearing spindle been better than those with three or two.
    Of course the vfd must be set up before run mine came with wrong parameters also but the seller provide me with the data on email how to put the correct parameters on the vfd.
    Sorry for the inconvenience!
  6. #146
    No its no problem Nick. Trouble is there are a couple of different VFD's that look the same but are completely different inside. You can tell by the front panel. Yes you are correct some time they have the wrong params. set.
  7. The Following 2 Users Say Thank You to Clive S For This Useful Post:
  8. #147
    Ok so i know what to order.
    Thanks guys.
    Grtz Bert.
  9. #148
    Thanks guys.
    Grtz Bert.
    So, i have been on a shopping spree.
    Painfull process :-)
    Unregulated psu 500va 68v
    Vfd 2.2kw
    spindle 2.2 kw
    WC pump (12v dc pc style)
    WC radiator 80mm (12v dc pc style)
    Clamp 80mm
    Collet set 6 pcs .. 2 4 6 8 10 12
    uc300eth
    2 very cheap 5 axis bob. for now. maybe ub1 later
    drivers 4x dm856
    5 proximity switches 6-36v NPN
    pulleys
    belts
    5 junction boxes
    20 or so glands
    cy cable 4x1
    6mm airline
    some 10mm pvc coolant hose.
    3m 15x50 dragchain
    Stuff to buy:
    2mm? allan key to lock the ballscrewnut in place.
    Did you guys make a flat spot on the ballscrews for more grubscrew grip?
    UCCNC
    Any suggestions on the pc specs?
    It will just be the cnc machine pc.
    Cad software will run on separate machine. Nvidia graphics icm F360?
    Router bits, I need suggestions on a starter kit :-) for these materials.
    Aluminum,
    mdf,
    soft / hardwood.
    And yes steel 8-), just for the sake of testing if it is capable. lets break some bits.
    Grtz Bert.
  10. #149
    I have no answers for you, just want to cheer you on ;)
    Did you order from China or EU?
    Just wondering about delivery times :)
  11. #150
    Hi nr1madman,
    Well eh only spindle/vfd is from a Germany warehouse. But still China.
    Steppers from UK/ Still China i guess.
    Belts from US i think.
    Fastners nuts bolts and small tools, local home improvement (Hornbach) store and places like Toolstation.
    Cant believe there is no profitable production /distribution possible anymore in Europe.
    Ok.
    Every thing else is from China directly.
    Ebay, Aliexpress.
    Some stuff like linear only took 1 week after "shipped" notice.. Carrier GLS.
    Tax through invoice after delivery.
    Most "free shipping" goods take 12- 15 working days.
    Now my drives , bobs, spindle, vfd, 80mm bracket have not arrived yet... so.
    I hope to finish fabricating soon.. that is... weeks.
    After that wiring.
    Grtz Bert.
  1. BUILD LOG: First time build - Steel Frame CNC Router
    By examorph in forum DIY Router Build Logs
    Last Post: 19-10-2023, 06:25 PM
  2. BUILD LOG: First Build 5 x 12 Steel Frame CNC router
    By Scott Damman in forum DIY Router Build Logs
    Last Post: 18-01-2017, 06:36 PM
  3. BUILD LOG: Steel frame cnc router design/build
  4. 600x900 Steel welded router build
    By embraced in forum Gantry/Router Machines & Building
    Last Post: 08-10-2014, 10:55 PM
  5. BUILD LOG: First steel diy CNC router build
