  1. #10
    Quote Originally Posted by driftspin View Post
    Hey guys,
    I need some advice on how you guys connected the 8 stepper wires to the 4 wire shielded cable.
    Did you guys just solder and heatshrink it to the cable?
    I also feel like i need to connect the cable shield to the body of the stepper motor.
    Some photos would do the trick :-)
    Any advice is welcome.
    Grtz Bert.
    I just soldered with heatshrink. Not pretty but it works :D
    My stepper motors are grounded through the machine frame.
    If connecting the wire shield aswell it might create a loop?
  2. The Following User Says Thank You to Nr1madman For This Useful Post:
  1. BUILD LOG: First time build - Steel Frame CNC Router
    By examorph in forum DIY Router Build Logs
    Last Post: 19-10-2023, 06:25 PM
  2. BUILD LOG: First Build 5 x 12 Steel Frame CNC router
    By Scott Damman in forum DIY Router Build Logs
    Last Post: 18-01-2017, 06:36 PM
  3. BUILD LOG: Steel frame cnc router design/build
  4. 600x900 Steel welded router build
    By embraced in forum Gantry/Router Machines & Building
    Last Post: 08-10-2014, 10:55 PM
  5. BUILD LOG: First steel diy CNC router build
