31-08-2018 #31
So i finally solved my 0-10 volt to VFD problem.
Some things in the manual are not completely like the vfd in real life.
The terminal vr does not exist.
Missing that one made me search for what i was missing earlier, terminal 1,2,3 J.
After staring puzzled to the vfd for a while i finally saw it, on the right side of the screwterminals
A jumper style selector. After moving the jumper from pin 2-3 to pin 1-2 the frontpanel potmeter did not work but the 0-10volt started working.
Just 1 problem left... only 9.62volt...
So not 24000 rpm but 23200 orso.
After filling up the cooling circuit i gonna try first cut tomorrow i hope.
Grtz Bert.
Verstuurd vanaf mijn SM-A320FL met TapatalkLast edited by driftspin; 01-09-2018 at 12:08 AM.
The Following User Says Thank You to driftspin For This Useful Post:
BUILD LOG: First Build 5 x 12 Steel Frame CNC router
By Scott Damman in forum DIY Router Build LogsReplies: 104Last Post: 18-01-2017, 06:36 PM -
600x900 Steel welded router build
By embraced in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 08-10-2014, 10:55 PM -
By ivars211 in forum DIY Router Build LogsReplies: 59Last Post: 28-07-2014, 08:29 PM
