07-10-2017 #10
Hi Clive S.
Hahah no, no movement yet.
Progress is slow.
Work related issues use up near all of my time. Well it pays for the bills.
I am still working on the gantry.
I need to get some bracing in, in the gantry uprights. Also i need to finish beefing up the mounting surfaces, some welds need finishing.
When all that is done the big pour is next.
After that a lot of big decisions are to be made.
I am near ready to order the linear parts.
I need advice on ballascrew end machining for pulley's.
Also .. will quality angle bearing bf bk type blocks fixed / float setup do?
Does one gain lots of rigidity by going fixed fixed? is it much more complicated to setup ?
I am now designing based on fixed/float setup.
So maximum speeds vs screw rpm vs pitch vs screw length and diameter are based on fixed float.
Grtz. Bert
BUILD LOG: First Build 5 x 12 Steel Frame CNC router
By Scott Damman in forum DIY Router Build LogsReplies: 104Last Post: 18-01-2017, 06:36 PM -
600x900 Steel welded router build
By embraced in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 08-10-2014, 10:55 PM -
By ivars211 in forum DIY Router Build LogsReplies: 59Last Post: 28-07-2014, 08:29 PM
