16-11-2017 #11
oh wow...
Just removed the sides.. the suggestion i read on this forum (Joe H
) using a simple packing tape on the sides worked out great. Easy removal of siding and great finish.
Lessons learned:
-My type of epoxy was not delamination proof under 5mm thickness.
Any thickness over 5mm would chip instead of easy peal off.
- Use taped sides, simple packing tape will prevent epoxy binding to sides and will give you great finsh.
- use small kit seam for leak proofing on inside of the sides to steal beam.
- used rich kit seam on the outside.
- use low height sides (20mm above steel is ok) for easy kit application.
- Use extra bracing in tipical H setup bridge.
- check for obvious leaks
before pouring.
- acryl kit can stop epoxy leaks on the outside of the siding.
- coat all kit seams with epoxy with a brush to seal up any leaks days before a pour.
- Inward leaning sides have meniscus too.
- not much worse but worse. maybe 7mm instead of 5mm
- Having stable temperature does positively influence surface finish.
ok i have to clean up sides of x axis remove meniscus then i can flip gantry and do the last pour.
Guys, thanx for all the great info accumulated on this forum. I could never have figured out all this stuff by my self.
Grtz..
Bert.
The Following User Says Thank You to driftspin For This Useful Post:
BUILD LOG: First Build 5 x 12 Steel Frame CNC router
By Scott Damman in forum DIY Router Build LogsReplies: 104Last Post: 18-01-2017, 06:36 PM -
600x900 Steel welded router build
By embraced in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 08-10-2014, 10:55 PM -
By ivars211 in forum DIY Router Build LogsReplies: 59Last Post: 28-07-2014, 08:29 PM
