    OK so I'm back looking for help.
    The Mrs has now suggested that she would like me to make her a square oak block with a bowl carve in to it so she can put her jewellery in at night.
    I gave her a breakfast bowl (which she chucked at me.... it missed).
    Now I really do not know where to start on this ........
    which bit to use.
    what tool path to set.
    I have tried but all I get is a round hole with flat sides....
    Any ideas ......
    What CAM software are you using ? can you draw the bowl in CAD and import as a 3D object ?
    i have v carve pro and
    and i have rhino 4 cad
    http://forum.vectric.com/viewtopic.php?f=5&t=19148
    But if you want it easy I think you need some 2.5D or 3D CAM software, something that can import stl files and generate the gcode. e.g. Cut3D
    thanks ... i need to look more in to it
    horses for courses... use a wood lathe
    :D
    Is it something like this you are wanting ?
    Only took a minute to design and tool path up im not sure about vcarve pro as im using aspire 4 but i can send you the gcode or maybe stl if i can figure that bit out
    I got around stuff like that( before I had CAM software) with a Macro B program but don't know if your machine has full Fanuc capability. If it does let me know and I'll try to help you out with a bit of If and Then code.
    Noel.
    Quote Originally Posted by Jester View Post
    That was exactly what I wanted to make thank you for your help i will be in touch.
    I would draw a circle the outside dia. and then cut it with a 'Z Profile' the shape of the bowl cross section using a ball nosed end mill.
  1. symmetrical hart shape in vectric v carve pro
    By cockneyrebel in forum Vectric
    Last Post: 24-02-2014, 02:55 PM
  2. Detailed plans needed for wood CNC machine
    By woodspiral in forum Open Source Designs & Plans
    Last Post: 08-02-2014, 11:44 PM
  3. Replies: 0
    Last Post: 19-08-2013, 12:46 AM
  4. Mach3 & V-Carve Problem
    By Ricardoco in forum Computer Software
    Last Post: 31-05-2013, 12:53 PM
  5. BUILD LOG: Wood router machine, 600x400
    By troyboy1 in forum DIY Router Build Logs
    Last Post: 05-12-2012, 12:47 AM
