14-08-2017 #3
https://warp9td.com/images/BOB_Vendo...line/ST-V2.pdf
The brown cable is connected to the 24v outlet offered from the BoB. Now i've tested the sensors and they should light when they have at least 12v passing through them but they are not when connected to the breakout board so It could just be a simple output setting that is not toggled in the mach 3 settings that I am not aware of.
The negative is connected to the ground on the board below the input for the limits.
Rob
Wiring 24v NPN Proximity Switch to 5v BOB - Why does'nt it work
By MikeyC38 in forum General ElectronicsReplies: 31Last Post: 21-10-2020, 02:42 AM -
Proximity limit switch problems
By davrich in forum General ElectronicsReplies: 16Last Post: 12-03-2018, 01:58 PM -
Proximity switch "contact bounce"
By Neale in forum General ElectronicsReplies: 18Last Post: 17-01-2017, 10:10 AM -
3 wire proximity switch help
By mikem in forum General ElectronicsReplies: 24Last Post: 06-10-2015, 03:24 AM -
Proximity switch NPN or PNP
By Matt81 in forum General ElectronicsReplies: 9Last Post: 19-04-2014, 11:38 AM
