is this how you connected the power suppy and proximity switch to the breakout board ?
Name:	BOB plus Proximity switches.jpg
if the breakout boards power supply negative in terminal is
connected to the limit switch common ground by the PCB's copper tracks it should work
but you may have to move the power supplies negative connection to the BOB's negative in to avoid noise problems
triggering the inputs
John
