  1. #13
    John,
    I have an early pic of the "proof of concept" I knocked up with what I had lying around,
    I've subsequently re-worked the spacer support with alternate bearings to reinstate the through capacity of the spindle, it does what I need in brass, bronze, aluminium and steel.
    I don't think it would have been up to much without the tensioner to remove backlash, without the support the stepper shaft bends if you tension the belt,
    Regards,
    Nick
  2. The Following User Says Thank You to magicniner For This Useful Post:
  1. 4th Axis Work Holding For Rectangular Work
    By magicniner in forum Workshop & Equipment
    Last Post: 20-10-2019, 03:02 AM
  2. B Axis indexing and easy workflow for repetitive cuts 4-axis
    By deemoss in forum General Discussion
    Last Post: 21-06-2017, 12:34 PM
  3. NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
  4. Precision metal processing (3 axis, 5 axis, 7 axis) OEM
    By 7AxisCNC in forum Manufacturer News
    Last Post: 17-05-2011, 02:04 PM
  5. CNC 4th Axis at work
    By Lee Roberts in forum Machine Discussion
    Last Post: 31-07-2009, 11:35 PM
