    I chose it for the decent through capacity which you don't get with harmonic drive versions, - Nick
    Picked up this harmonic drive some time ago for a 4th axis project, not yet got round tuit. 50 -1 with 25mm through and pre-loaded cross roller bearing on the output ring
    I just found these things existed but I already feel a deep need to own one, was this an e-bay find?
    Yes, came across it after I had bought a 5phase stepper with 50-1 harmonic drive ( 25000 steps /rev ) which I was going to belt drive a head 2-1 so that I could incorporate a through hole. I also have some very low backlash 5 phase 10-1 (5000 steps/rev ) epicyclic drives that I thought I might use with perhaps ~4-1 belt drive.
ID:	22616Click image for larger version.
    I have now bought a 50:1 harmonic to play with, eBay item number: 291926642351
    I thought maybe connect it to a shaft using my favorite Myford change wheels. Not easy to cut the middle out 100% concentric so I would have to spring two together, that seems to do the trick if you want low backlash with Myford wheels. I think I could enjoy this. Somewhere in my junk boxes I have a new pair of 40mm self-aligning, flange bearings, featuring grub screws on the extended inner race. They could easily become a part of this.
    They come in various sizes, 11 is quite a small one, do you know shaft sizes
    I use lots of harmonic drives for my motion control rigs. I buy them second hand from ebay, but I have also bought a couple of modern brand new ones from the Harmonic Drive rep in the UK. They are very expensive new. HQ is in Germany but usually made in Japan, they own the monopoly, so the cheapo Chinese contraptions may not live up to expectations re. "zero" backlash, quality of bearings and so on. A brand new size 25 HD will usually cost a couple of thousand. I paid £1500 for each size 11 for a camera rig. They are beautifully made.
    The one above from Johnattuk is a proper one with very good angular bearings. These usually come from small robotic machines that are decommissioned, a lot from S Korea, and a bit old, but perfectly usable. Some work perfectly, some have seen better days and will work, although they may be a bit bumpy at certain speeds, which you wouldn't probably notice on cnc rigs, but you do notice in motion control where perfect smoothness throughout the range is paramount.
    The one you bought, Robin is too small, being size 11, with small bearings. You need at least a size 25, with size 14 being a bit marginal. Typical price for a good decent second hand size 25 with hollow shaft is around £450.
    Here is a render of one of mine showing both ends
    Edward
    And this will give you a perspective on sizes. Size 11, size 14 and size 25
    Quote Originally Posted by Edward View Post
    Lightweight ;), here's a size 50:
Name:	2017-01-21 20.18.39.jpg
    I had two of these sitting in my shed for 5-6 years - like Robin I found out about them and immediately decided I must have two. Then I got very sidetracked, so I sold one recently and held on to the other. I think I'm more interested now in coaxing a high torque motor into a direct drive axis, as the cost of encoders is decreasing. Seems more elegant.
    One interesting point with harmonic drives is that although they don't exhibit backlash (if well made), they still do have some hysteresis. Still, beats buying a chuck driven from a stepper motor via a rubber band.
    Quote Originally Posted by johnsattuk View Post
    I think it is 6mm in, 12mm out.
    Robin if it's like mine in size 11, then it's probably 6mm in, 10mm out.
    And Jonathan, I also have a size 50 monster that I use on a crane rig, weighs a bit that one:)
    Edward
    I thought maybe connect it to a shaft using my favorite Myford change wheels..
    Surely you'll be using Anti-Backlash gears from HPC Gears as it would be a strange choice to add backlash in the primary drive (regardless of how small an error this would introduce) of a system designed specifically to avoid backlash?
  1. 4th Axis Work Holding For Rectangular Work
    By magicniner in forum Workshop & Equipment
    Last Post: 20-10-2019, 03:02 AM
  2. B Axis indexing and easy workflow for repetitive cuts 4-axis
    By deemoss in forum General Discussion
    Last Post: 21-06-2017, 12:34 PM
  3. NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
  4. Precision metal processing (3 axis, 5 axis, 7 axis) OEM
    By 7AxisCNC in forum Manufacturer News
    Last Post: 17-05-2011, 02:04 PM
  5. CNC 4th Axis at work
    By Lee Roberts in forum Machine Discussion
    Last Post: 31-07-2009, 11:35 PM
