Thread: will this 4th axis work
20-08-2017 #31
20-08-2017 #32
Well enough:
https://www.youtube.com/watch?v=lVuBEEceWJ4
http://www.mycncuk.com/threads/3341-...illing-machine
http://www.mycncuk.com/threads/11220...-as-a-4th-Axis
Unfortunately I ran the stepper motor on the rotary table into my milling machine column (wasn't looking) last year and bent the worm gear, so I do have another doorstop! I'm now wondering if these are better than the price suggests:
http://www.ebay.co.uk/itm/Precision-...sAAOSwZ4dZHZkC
The problem with the direct belt drive method is the stiffness of the belt is quite poor compared to a harmonic or worm drive. Of course, it can be useful but that depends somewhat on the diameter of the material, your accuracy requirement and other factors. If the rotary table above is any good - i.e. "most" of the backlash can be adjusted out, then that plus a 1Nm stepper motor seems like an attractive option.
20-08-2017 #33
20-08-2017 #34
Robin if it's like mine in size 11, then it's probably 6mm in, 10mm out.
And Jonathan, I also have a size 50 monster that I use on a crane rig, weighs a bit that one:)
Edward
20-08-2017 #35
28-08-2017 #36
28-08-2017 #37
Not just the fine pitch but also the fact that they are flexible to mesh and I am not totally sure about the inner workings, but I think they have one more tooth than the gears they mesh with, or vice versa. Incredible concept and I guess very difficult to machine such precision.
Edward
28-08-2017 #38
28-08-2017 #39
I have to get those headless screws out before I can reassemble.
M2.5 and darned close to the bendy cog. I don't have anything suitable to grab them with.
Any ideas?
28-08-2017 #40
Have you tried two or three nuts locked together perhaps with heavy duty locktite retainer as well
4th Axis Work Holding For Rectangular Work
By magicniner in forum Workshop & EquipmentReplies: 1Last Post: 20-10-2019, 03:02 AM -
B Axis indexing and easy workflow for repetitive cuts 4-axis
By deemoss in forum General DiscussionReplies: 1Last Post: 21-06-2017, 12:34 PM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM -
CNC 4th Axis at work
By Lee Roberts in forum Machine DiscussionReplies: 15Last Post: 31-07-2009, 11:35 PM
