    Boyan - the lathe does not have a gearbox, just a six position belt drive. I anticipate replacing the belt drive with a 20mm timing belt setup. Currently I am thinking 22T driver to 112T driven.
    Will only be used for wood plastic and maybe aluminium. Thanks for your information. I have no knowledge of servo`s. Just trying to use what I have at this time.
    You could use the belt calculator web for finding the right belt https://www.bbman.com/belt-length-calculator/ , i asume you know of it, but anyway here is the link.
    it seems that 17-18T is better choice as it has 6 teeth in mesh, versus 7 teeth for 20t, so you lose almost nothing. 6 teeth is the minimum recommended for HTD 5 belts, so you are ok there.
    so 17x7=119t, which is better as its a whole number of ratio . Its not bad 1:7 ratio . Its 180mm diameter puley, the big one
    I can generate you the pulley profile if you need. Thingverse also there is a pulley generator.
    Boyan - Have you printed pulleys? I had not considered that option until you mentioned Thingverse. - Could print a 180mm dia. quite nicely in ABS. Got to be a cheap option if it would be serviceable? Thank you for the idea.
    You can increase the number of "Teeth in Contact" to at least 50% of the count on the driving pulley by using idler pulleys to generate a serpentine belt path as is done in the automotive industry,
    - Nick
    Nick - Yes adding a flat side idler would be quite simple. Thanks.
    Boyan - Ref. Thingiverse. Did you reference "Customizable Gear4"?
    Would you recommend any particular tooth form or pitch please?
    Sorry missed that on your reply Boyan. HT5.
    I have printed with great result.Small as GT2. I will advice PETG pulley. PLA will work also. ABS not. Nylon, even better.
    HDT5 15mm will work great
    https://www.thingiverse.com/thing:16627
  9. The Following User Says Thank You to Boyan Silyavski For This Useful Post:
  1. FOR SALE: Sieg C3 Mini Lathe
    By Jonathan in forum Items For Sale
    Last Post: 07-05-2011, 06:19 PM
  2. Ron Steele Mini Lathe CNC Conversion - Z Axis Leadscrew?
    By No1_sonuk in forum Lead Screws, Nuts & Supports
    Last Post: 17-05-2010, 12:47 PM
  3. A Mini Lathe
    By irving2008 in forum Milling Machines, Builds & Conversions
    Last Post: 03-05-2010, 04:11 PM
  4. WANTED: SIEG C3 Mini Lathe
    By derekm in forum Items Wanted
    Last Post: 07-04-2010, 08:35 PM
  5. Mini Lathe alignment
    By pequod in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 29-06-2009, 06:40 PM
