    Quote Originally Posted by Leadhead View Post
    Boyan - thanks for your advice. Do you reinforce the the pulley centre, as I will try first with PLA and wondered if it would take the torque from the shaft?
    I print such things extrusion width 0.5mm, with 0.4mm nozzle at 0.2mm layer height , 4 perimeters at least and 50% infill at 90 degree mesh. I don't want to brag, but i consider myself already an expert and i carefully analyze and have in mind many things before a print so results are always working. For things like pulleys and so i will carefully look at the preview to see if there are any unwanted spaces due to object size divided by extrusion width and if needed will change a parameter until i am happy. needless to say when i design something for printing, i will know from the beginning how exactly i would like it printed .
    I would have used a nice print, then ream the hole then use Loctite medium or high strength retaining compound for a permanent bond, not superglue.
    Boyan - I will follow your advice carefully. There is an interesting new update to Simplify3D which addresses void issues so I will study that to see if it might be used to good effect.
    I am indebted to you for your assistance. Thank you once again.
    Sven's Avatar
    Lives in a, Netherlands. Last Activity: 07-05-2020 Has been a member for 9-10 years. Has a total post count of 46. Received thanks 4 times, giving thanks to others 0 times.
    Ik have a 4th axis that I can use as a lathe, it has a 12 nm closed loop stepper.
    With help from a friend I can now run it in both positioning mode and continuous mode.
    It has a 1:1 transmission and can run up to 1500 rpm, which scares me....:
    I use linuxcnc.
Name:	2017-08-14 13.52.47.jpg
  1. FOR SALE: Sieg C3 Mini Lathe
    By Jonathan in forum Items For Sale
    Last Post: 07-05-2011, 06:19 PM
  2. Ron Steele Mini Lathe CNC Conversion - Z Axis Leadscrew?
    By No1_sonuk in forum Lead Screws, Nuts & Supports
    Last Post: 17-05-2010, 12:47 PM
  3. A Mini Lathe
    By irving2008 in forum Milling Machines, Builds & Conversions
    Last Post: 03-05-2010, 04:11 PM
  4. WANTED: SIEG C3 Mini Lathe
    By derekm in forum Items Wanted
    Last Post: 07-04-2010, 08:35 PM
  5. Mini Lathe alignment
    By pequod in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 29-06-2009, 06:40 PM
