18-08-2017 #3
Same here - I used Cut2D and Cut3D extensively when I started out machining and whilst they get you going quickly, there are some quirks, which to my mind are down right ruinous to cutters and work pieces.
The 3D finishing passes using ballnose cutters are a prime example, where it will take plunge cuts on a whim on steep edges and then mill out at whatever depth that plunge goes to. You can get away with such things in wood mostly, but aluminium results in snapped or welded tools.
Fusion 360's CAM whilst not quite as good as Solidworks and iMachining (OK quite a long way off in terms of adaptive/trochoidal clearing configuration) does at least have enough strategies and "intelligence" to get most jobs done quickly.
That said I still use Cut2D to convert PDF guitar plans into .dxf before importing into Fusion, so that still has a place in my software "toolbox".
Oh another CAM package I still use for intricate 3D carving is DeskProto, as it can handle high polygon stl files and Fusion just refuses to do those properly with anything approaching 8-9000 polygons (it doesn't like the triangle format, which is a bit bizarre as triangle polys are the lowest common denominator in computer 3D rendering...).Last edited by Washout; 18-08-2017 at 11:47 AM.
My CNC Projects: https://www.youtube.com/imadethisoncnc
conect software what do these 4 do, pocket, drilling and profile?
By windows20 in forum Machine Control SoftwareReplies: 5Last Post: 31-08-2016, 03:20 PM -
Feeds and speed guide/pocket book
By maritimesbob in forum Marketplace DiscussionReplies: 3Last Post: 10-11-2013, 09:38 AM -
Circular Pocket problem?
By Leadhead in forum Machine DiscussionReplies: 6Last Post: 03-10-2013, 01:05 PM -
crazy idea
By kingcreaky in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 27-08-2013, 07:54 PM
