18-02-2018 #9
@ Boyan Silyavski,
As expected, your pics shows these cheap crap HVLPs without having the needles extracted. For example, the so called "K3" is a cheap copy of the Iwata's HVLP - I guess you already know that. According to instructions, the yellow marked screw need to be extracted in order to release the spring and slide the needle out and clear the way to easily clean the parts. None of this can happen and as far as I see in your picture, you also cannot remove the needle. So, I wonder how you clean the needle... or maybe you dont?
Show the K3 FULLY disassembled! Can you? I bet not! Know why? Because these screws (that should be possible to be extracted) are manufactured by Chinese copy makers as one part fixed on aluminum body.
Long story short? As said before, I was fooled by your enthousiastic review and believed that these cheap crap can do the job. Obviously, they cannot
BUILD LOG: Small workshop CNC router, steel base, planning on ATC
By spresv in forum DIY Router Build LogsReplies: 24Last Post: 07-02-2017, 04:28 PM -
Cheap small steppers and drivers
By m_c in forum Stepper & Servo MotorsReplies: 9Last Post: 31-05-2016, 08:59 PM -
is it possible to do a diy help spray machine?
By reefy86 in forum Machine DiscussionReplies: 2Last Post: 18-01-2016, 11:38 AM -
Powder coat & paint
By craigrobbo in forum Metal Finishing TechniquesReplies: 6Last Post: 06-08-2012, 09:06 PM -
NEW MEMBER: Manouchehr from small workshop
By Manouchehr in forum New Member IntroductionsReplies: 1Last Post: 22-08-2010, 10:20 AM
