Thread: Spindle help?
    Hi All
    As Usuall I need help. I have an ER11, 300 watt brushless spindle/motor that I aquired.(legit but long story)...And wish to use for a MCB / inlay router. (bed mill, etc.)
    This seems to to be a quality item. All stainless construction and came from a lens grinding machine, so should have low run out and ER11 collet is perfect for the application I need.
    I have contacted Loadpoint and they have been very helpful. But without sending them the motor and the best part of a grand they cant help with the driver.
    Motor Power
    Red wire = Phase A
    White wire = Phase B
    Black wire = Phase C
    Hall sensors
    Thin blue wire = +5V
    Thin brown wire = A
    Thin orange wire = B
    Thin yellow wire = C
    Thin green wire = earth/ground
    Thin purple wires = thermistors (not needed)
    Their best guess is 6 Pole and 180Volt. I have bought a controller from the bay but it is only 100volt max.
    Will this contoller work and how do I make a 100volt psu?
    If not can anybody help? I was hoping that spindle control is easier than servo control and therefore maybe an easyish solution.:whistling:
    Attached Thumbnails Attached Thumbnails MAN-SBAUG.pdf   Click image for larger version.
ID:	736   Click image for larger version.
  2. Replies: 0
    Last Post: 13-11-2013, 07:50 PM
  3. Spindle lock mechanism for 2.2kW china spindle
    By Jonathan in forum Generic Chinese Spindles
    Last Post: 13-08-2012, 08:39 PM
  4. WANTED: Spindle holder for 1.5kw Chinese spindle.
    By jcb121 in forum Items Wanted
    Last Post: 14-10-2011, 02:07 PM
  5. DIY Spindle - What type of bearings are best suited for a spindle.
    By 8iggles in forum Spindles & Drive Motors
    Last Post: 09-02-2011, 10:15 PM
