Thread: Spindle help?
14-08-2009 #5
Thanks Gary, That makes sense. The 180v was only a guess from loadpoint. If I power up the motor from this driver at say 50v and then measure the speed compared to the design max speed can I calculate the actual voltage? I always presumed the speed was due to the PWM frequency. Do you have a suitable driver? and if so how much?
Very good point. didnt even think about that. Need to build a PSU to test it then. is there any way I can accurately check for play without powering it up. Ive done the obvious checks by hand and it feels smooth with no sign of radial or axial play.Ross77,
Have you tried that motor or actually know it runs as from the picture of the er11 collet shows a lot of glass slurry and that stuff is a killer if it gets near ant rotating shaft or bearing. Best to check before you part with the readies for a driver.
peter
Chinese 300W DC spindle - is the spindle shaft grounded?
By HankMcSpank in forum Spindles & Drive MotorsReplies: 44Last Post: 26-11-2016, 07:25 PM -
CNC Spindle Repair and Spindle Replacement for any Machine of any Manufacturer
By spindeldoctor in forum Manufacturer NewsReplies: 0Last Post: 13-11-2013, 07:50 PM -
Spindle lock mechanism for 2.2kW china spindle
By Jonathan in forum Generic Chinese SpindlesReplies: 8Last Post: 13-08-2012, 08:39 PM -
WANTED: Spindle holder for 1.5kw Chinese spindle.
By jcb121 in forum Items WantedReplies: 19Last Post: 14-10-2011, 02:07 PM -
DIY Spindle - What type of bearings are best suited for a spindle.
By 8iggles in forum Spindles & Drive MotorsReplies: 18Last Post: 09-02-2011, 10:15 PM
