  1. #6
    Lives in Marple Stockport, United Kingdom. Last Activity: 10 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,347. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by charlieuk View Post
    soldering it sounds like a good move I will be sure to do that, did you take the 4 pins out and then modify it so the wires went through the top? along with the earth?
    It is a common mistake not to securely fix the cable to the VFD plate so that there is no strain on the plug, If you take the cap off be careful as the water inlet and outlet might need to be resealed.
  2. The Following User Says Thank You to Clive S For This Useful Post:
