A recent thread here talked about the failure rates of the VFDs that come with Chinese spindles. They are cheap, but could we do better?
I just wondered if anyone had successfully used VFDs sourced elsewhere, with their Chinese spindle? I have used Siemens and Mitsubishi VFDs to drive three phase mains induction motors on my manual mill and lathes with great results, and such VFDs are readily available used on eBay for decent prices. They are well made, and well proven designs, aimed at industrial use. They also appear to support the 400Hz output frequencies that the Chinese spindles require. So if such kit could be deployed with a Chinese spindle, maybe an improved degree of reliability would result?
Keen to hear from anyone with thoughts or experiences on this!
Graeme
23-08-2017 #2
One of the issues here seems to be the high degree of variability in reliability of these things. I'm using the usual HY VFD and have been for around 5 years. If it blows up tomorrow, I'm not sure whether I would junk it and replace with another cheap one, or go down the "industrial" route. I have an ABB inverter driving my three-phase lathe and I have to say that it is built like a brick outhouse compared to the HY, but there's a bit of a price difference...
The Following 2 Users Say Thank You to Neale For This Useful Post:
23-08-2017 #3
Here in the US, Hitachi is the preferred brand for use with Chinese spindles. Lots of people are using them.
I went with the Huanyang for $135. The Hitachi is about $350.Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
The Following User Says Thank You to Ger21 For This Useful Post:
23-08-2017 #4
I'd agree that the Huanyang is a good option at the asking price, but if you're happy to go used, then bargains can definitely be found. I bought a couple of vector control grade Mitsubishi units, plus a Siemens Micromaster for around the £60 each mark. Sometimes takes a little patience - or luck! But I feel the playing field is a little more level in that case. Question of whether a used industrial unit is a better bet than a new Huanyang. You won't know for sure until one goes pop!
Gerry - do you have a model number for the Hitachi units people like over there? Would be a useful data point.
Graeme
23-08-2017 #5Gerry
24-08-2017 #6
Thanks for that, Gerry. Had a bit of a look around, and I find no bargains to be had. So in that case, Huanyang wins big time on price!
Taking the question a little further - is there anything special or specific about the Huanyang VFD that makes it a particularly good choice for use with the Chinese spindles? Or in reality can any decent VFD be used? Certainly when I converted my manual machines to variable speed drives, I just chose respectable makes with a good enough spec, when they came up on eBay. It worked well. I kind of see the spindle as a different beast - but maybe it isn't? It obviously runs at much higher frequencies than a regular 50Hz type induction motor, but otherwise? Or am I missing some subtleties here?
24-08-2017 #7
27-08-2017 #8
The very last thing you should do is credit someone who, unlike you, could be arsed to Google search some manuals, read them and hand you the results on a platter ;-)
It's all good fun! :DYou think that's too expensive? You're not a Model Engineer are you? :D
The 2.2Kw Chinese Spindles - Info, Setup and Advice + More
By Husky in forum Generic Chinese SpindlesReplies: 222Last Post: 22-01-2021, 06:54 PM -
Chinese Spindles
By Ricardoco in forum Generic Chinese SpindlesReplies: 123Last Post: 05-12-2016, 12:16 AM -
motor power and chinese spindles power HELP
By DigiSoft in forum Spindles & Drive MotorsReplies: 5Last Post: 17-09-2013, 12:17 AM -
Chinese spindles
By Colin Barron in forum Marketplace DiscussionReplies: 15Last Post: 23-08-2011, 08:58 PM -
Chinese 1.5kw Spindles
By jcb121 in forum Generic Chinese SpindlesReplies: 12Last Post: 28-07-2011, 06:20 PM
