Here in the US, Hitachi is the preferred brand for use with Chinese spindles. Lots of people are using them.
I went with the Huanyang for $135. The Hitachi is about $350.Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
The Following User Says Thank You to Ger21 For This Useful Post:
23-08-2017 #2
I'd agree that the Huanyang is a good option at the asking price, but if you're happy to go used, then bargains can definitely be found. I bought a couple of vector control grade Mitsubishi units, plus a Siemens Micromaster for around the £60 each mark. Sometimes takes a little patience - or luck! But I feel the playing field is a little more level in that case. Question of whether a used industrial unit is a better bet than a new Huanyang. You won't know for sure until one goes pop!
Gerry - do you have a model number for the Hitachi units people like over there? Would be a useful data point.
Graeme
23-08-2017 #3Gerry
24-08-2017 #4
Thanks for that, Gerry. Had a bit of a look around, and I find no bargains to be had. So in that case, Huanyang wins big time on price!
Taking the question a little further - is there anything special or specific about the Huanyang VFD that makes it a particularly good choice for use with the Chinese spindles? Or in reality can any decent VFD be used? Certainly when I converted my manual machines to variable speed drives, I just chose respectable makes with a good enough spec, when they came up on eBay. It worked well. I kind of see the spindle as a different beast - but maybe it isn't? It obviously runs at much higher frequencies than a regular 50Hz type induction motor, but otherwise? Or am I missing some subtleties here?
24-08-2017 #5
The only thing that makes it a good choice is the price. I would imagine that any of the "name brands" would be better, but probably not noticeably better.
One thing I found with my Huanyang is that they don't contain the circuitry for a braking resistor, but the terminals are there. The sellers apparently special order them this way to save money. I found out after I purchased a braking resistor.Gerry
24-08-2017 #6
Interesting that you say price really is the only factor. But then it truly is inexpensive when compared to the well known brands - almost three to one if you buy new. It seems your experiences with the lack of braking resistor support might just show how some of that price difference is achieved - cut to the bone. I'm sure the branded VFDs also uplift their prices a bit because they can. But for the functionality you get, the Huanyang truly is a bargain.
I think I'll do some trawling for used VFDs of the right power rating, and see what I can find. I'm keen to give this a try, and thankfully I'm in no immediate hurry!
The Following User Says Thank You to GND For This Useful Post:
24-08-2017 #7
I would have bought a Hitachi, but wanted to test my application with a cheap Huanyang first. I'm controlling two spindles with one VFD, using contactors to switch between the spindles. If I make any mistakes, the VFD will be a casualty.
Gerry
The 2.2Kw Chinese Spindles - Info, Setup and Advice + More
By Husky in forum Generic Chinese SpindlesReplies: 222Last Post: 22-01-2021, 06:54 PM -
Chinese Spindles
By Ricardoco in forum Generic Chinese SpindlesReplies: 123Last Post: 05-12-2016, 12:16 AM -
motor power and chinese spindles power HELP
By DigiSoft in forum Spindles & Drive MotorsReplies: 5Last Post: 17-09-2013, 12:17 AM -
Chinese spindles
By Colin Barron in forum Marketplace DiscussionReplies: 15Last Post: 23-08-2011, 08:58 PM -
Chinese 1.5kw Spindles
By jcb121 in forum Generic Chinese SpindlesReplies: 12Last Post: 28-07-2011, 06:20 PM
