    GND's Avatar
    Lives in Cambridge, United Kingdom. Last Activity: 16-07-2024 Has been a member for 9-10 years. Has a total post count of 85. Received thanks 3 times, giving thanks to others 11 times.
    Thanks for that, Gerry. Had a bit of a look around, and I find no bargains to be had. So in that case, Huanyang wins big time on price!
    Taking the question a little further - is there anything special or specific about the Huanyang VFD that makes it a particularly good choice for use with the Chinese spindles? Or in reality can any decent VFD be used? Certainly when I converted my manual machines to variable speed drives, I just chose respectable makes with a good enough spec, when they came up on eBay. It worked well. I kind of see the spindle as a different beast - but maybe it isn't? It obviously runs at much higher frequencies than a regular 50Hz type induction motor, but otherwise? Or am I missing some subtleties here?
    The only thing that makes it a good choice is the price. I would imagine that any of the "name brands" would be better, but probably not noticeably better.
    One thing I found with my Huanyang is that they don't contain the circuitry for a braking resistor, but the terminals are there. The sellers apparently special order them this way to save money. I found out after I purchased a braking resistor.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    GND's Avatar
    Interesting that you say price really is the only factor. But then it truly is inexpensive when compared to the well known brands - almost three to one if you buy new. It seems your experiences with the lack of braking resistor support might just show how some of that price difference is achieved - cut to the bone. I'm sure the branded VFDs also uplift their prices a bit because they can. But for the functionality you get, the Huanyang truly is a bargain.
    I think I'll do some trawling for used VFDs of the right power rating, and see what I can find. I'm keen to give this a try, and thankfully I'm in no immediate hurry!
  5. The Following User Says Thank You to GND For This Useful Post:
  6. #5
    I would have bought a Hitachi, but wanted to test my application with a cheap Huanyang first. I'm controlling two spindles with one VFD, using contactors to switch between the spindles. If I make any mistakes, the VFD will be a casualty.
    Gerry
  7. #6
    GND's Avatar
    Not unreasonable!
  1. The 2.2Kw Chinese Spindles - Info, Setup and Advice + More
    By Husky in forum Generic Chinese Spindles
    Last Post: 22-01-2021, 06:54 PM
  2. Chinese Spindles
    By Ricardoco in forum Generic Chinese Spindles
    Last Post: 05-12-2016, 12:16 AM
  3. motor power and chinese spindles power HELP
    By DigiSoft in forum Spindles & Drive Motors
    Last Post: 17-09-2013, 12:17 AM
  4. Chinese spindles
    By Colin Barron in forum Marketplace Discussion
    Last Post: 23-08-2011, 08:58 PM
  5. Chinese 1.5kw Spindles
    By jcb121 in forum Generic Chinese Spindles
    Last Post: 28-07-2011, 06:20 PM
