Thread: Temperamental spindle
26-08-2017 #11
I am all ears. I was trying to establish if the the relay contact on the board (or control system) had gone wonky.
shorting FOR and DCM should start the spindle I hope
Problem is it is, always ambiguous when trying to sort problems out at a distance. I would like to know the outcome to the problem that way we all learn and can help one another.
It could well be that the vfd has packed up...Clive
27-08-2017 #12
I hear you. Difficult to diagnose over a forum, much quicker if you were there in person.
I'd only just read this thread and had to comment in case Mark messed around with the control cabinet without absolutely confirming FOR and DCM did not run the spindle.
I have a sinking feeling this is a new VFD but lets not get ahead of ourselves.
Mark, if you can confirm the above, the next steps would be to check the settings on the VFD. I'd be surprised if Dean set this up wrong so maybe you accidentally altered one of them? I'm no VFD expert but maybe you set a current limit? Have a read here, post #6, and see how your settings compare:
http://www.mycncuk.com/threads/5814-...nd-Advice-More
27-08-2017 #13I agree but I thought in post #4 I tried to establish that he had just removed the two cables from the vfd end and put a link in place. (to prove if the vfd would run)I'd only just read this thread and had to comment in case Mark messed around with the control cabinet without absolutely confirming FOR and DCM did not run the spindle.
I also agree that if it is a new vfd then the settings WILL be the problem...Clive
27-08-2017 #14
09-09-2017 #15
Hi gentlemen,
thanks for all the posts.
Apologies for me taking my time, I've used the router a few times since last post, and all seemed well, until today- when it's back with a vengeance.
It took four attempts but the spindle came to life, however it stopped- without cause after 2 mins.
Once again I'm having to wait- I believe this may be a clue to the issue- the fact I have to wait several hours until the spindle will run again. This is the original VFD, installed by dean. routerCNC, in regards to your question about the behaviour of the spindle when FOR and DCM were connected, technically it didn't power the spindle up- however, I would say it was successful as it made a 'click' - something the VFD has always done- Dean told me this was something in the VFD to do with acceleration, and from day 1 it's always been a little coy at starting up at very slow (sub 6krpm) or very fast (over 20k) speeds, usually taking a few attempts, though it's never been a big deal. I assume short circuiting it in that way makes it power up to full speed, at which point it does what it would have always done, and clicks(think this click would be a MCB?) and prevents the spindle from running.
This isn't what is happening at the moment- I hit the spindle button on mach3 and it's totally unresponsive, the VFD sits there happily blinking away, no MCB noise, no power to the spindle.
I know it's a bit confusing, hope I've at least done an ok job of explaining it :(Last edited by mark84; 09-09-2017 at 01:27 PM.
09-09-2017 #16
The vfd settings:
Pd5-400
Pd4-400
Pd3-200.01
Pd6-002.50
Pd7-0.50
Pd8-220
Pd9-015.0
Pd11-01.20
Pd14-0.3
Pd15-1.0
Pd72-400
Pd143-05.0
Pd142-5.0
Pd144-3000
Thanks so much :)
09-09-2017 #17
I was curious, is it possible to set the spindle speed on the vfd, and start it up, at least if I could do that I could do some milling without fear of another broken end mill!?
The router has never had heavy usage, I can't reliably say total hours used, but it's likely a typical week it's in use an hour, over the past 3(??) Years.Last edited by mark84; 09-09-2017 at 06:50 PM.
10-09-2017 #18
Sorry for my wall of text, I misunderstood the original instructions about joining For and Dcm, I didn't think you meant with mach 3 connected.
I can confirm that connecting these two and starting the toolpath does bring the spindle to life, disconnecting the two while the spindle is running stops it, and simply pressing the spindle off via mach3 slows it(but doesn't stop it fully) to about 70rpm.
10-09-2017 #19
Pd 143 should be set to 2 its hard to believe it ever started with this set to 5
Pd 3 set to 400
Pd 11 I would set to 55 so that the lowest spindle speed would be about 3300
Pd 14 set to 2
Pd 15 set to 2
Pd 7 set to 1.5
Pd 142 set to 7 (if 2.2kw)
Try these and report backLast edited by Clive S; 10-09-2017 at 10:48 AM.
10-09-2017 #20
Thank you, Clive. It'll be a few days, but I'll keep you informed.
Chinese 300W DC spindle - is the spindle shaft grounded?
By HankMcSpank in forum Spindles & Drive MotorsReplies: 44Last Post: 26-11-2016, 07:25 PM -
TB6560 controller Runs spindle on power up When Mach3 plunges spindle stops
By RoyT in forum Spindles & Drive MotorsReplies: 5Last Post: 29-09-2014, 02:42 PM -
CNC Spindle Repair and Spindle Replacement for any Machine of any Manufacturer
By spindeldoctor in forum Manufacturer NewsReplies: 0Last Post: 13-11-2013, 07:50 PM -
Spindle lock mechanism for 2.2kW china spindle
By Jonathan in forum Generic Chinese SpindlesReplies: 8Last Post: 13-08-2012, 08:39 PM -
DIY Spindle - What type of bearings are best suited for a spindle.
By 8iggles in forum Spindles & Drive MotorsReplies: 18Last Post: 09-02-2011, 10:15 PM
