    Quote Originally Posted by mark84 View Post
    I couldn't find any issues with the wiring, though I've taken the connections out and cleaned them before tightening up again, and it's working, I'm unsure if that's just coincidental but at least it's ok for now.
    If the problem keeps happening could I move the connection to the next port across?
    Thanks for your help Clive :)
    Mark Not sure what you mean by "next port across" if you mean the next terminal I would have to look into the manual as I am not familiar with he CS labs board. Let us know if it has been cured after a few hour of use.
    Clive
    I've just read post #3 and to me it does not sound like joining FOR and DCM is running the spindle all the time. Have a read and see if you agree.
    Mark,
    When you connected FOR and DCM the spindle briefly accelerated then cut out. It remained stationary until you disconnected FOR and DCM at which point nothing happened until the electronics had 'spooled down' to a low rpm at which point the spindle burst into life and tracked the speed down to zero. As if there is a dead spot above a very low rpm at which the spindle will not turn. Is this what you observed?
    If I got this wrong please carry on. If not suggests VFD is faulty or has wrong settings?
    I am all ears. I was trying to establish if the the relay contact on the board (or control system) had gone wonky.
    shorting FOR and DCM should start the spindle I hope
    Problem is it is, always ambiguous when trying to sort problems out at a distance. I would like to know the outcome to the problem that way we all learn and can help one another.
    It could well be that the vfd has packed up.
  4. The Following User Says Thank You to Clive S For This Useful Post:
  5. #4
    I hear you. Difficult to diagnose over a forum, much quicker if you were there in person.
    I'd only just read this thread and had to comment in case Mark messed around with the control cabinet without absolutely confirming FOR and DCM did not run the spindle.
    I have a sinking feeling this is a new VFD but lets not get ahead of ourselves.
    Mark, if you can confirm the above, the next steps would be to check the settings on the VFD. I'd be surprised if Dean set this up wrong so maybe you accidentally altered one of them? I'm no VFD expert but maybe you set a current limit? Have a read here, post #6, and see how your settings compare:
    http://www.mycncuk.com/threads/5814-...nd-Advice-More
  6. The Following User Says Thank You to routercnc For This Useful Post:
  7. #5
    I agree but I thought in post #4 I tried to establish that he had just removed the two cables from the vfd end and put a link in place. (to prove if the vfd would run)
    I also agree that if it is a new vfd then the settings WILL be the problem.
  8. The Following User Says Thank You to Clive S For This Useful Post:
  9. #6
    Sorry Clive I've confused you. I meant he may need to buy a new VFD. As I understand it this is the original one the Dean installed.
  10. The Following User Says Thank You to routercnc For This Useful Post:
  11. #7
    mark84's Avatar
    Lives in doncaster, United Kingdom. Last Activity: 3 Weeks Ago Has a total post count of 45.
    Hi gentlemen,
    thanks for all the posts.
    Apologies for me taking my time, I've used the router a few times since last post, and all seemed well, until today- when it's back with a vengeance.
    It took four attempts but the spindle came to life, however it stopped- without cause after 2 mins.
    Once again I'm having to wait- I believe this may be a clue to the issue- the fact I have to wait several hours until the spindle will run again. This is the original VFD, installed by dean. routerCNC, in regards to your question about the behaviour of the spindle when FOR and DCM were connected, technically it didn't power the spindle up- however, I would say it was successful as it made a 'click' - something the VFD has always done- Dean told me this was something in the VFD to do with acceleration, and from day 1 it's always been a little coy at starting up at very slow (sub 6krpm) or very fast (over 20k) speeds, usually taking a few attempts, though it's never been a big deal. I assume short circuiting it in that way makes it power up to full speed, at which point it does what it would have always done, and clicks(think this click would be a MCB?) and prevents the spindle from running.
    This isn't what is happening at the moment- I hit the spindle button on mach3 and it's totally unresponsive, the VFD sits there happily blinking away, no MCB noise, no power to the spindle.
    I know it's a bit confusing, hope I've at least done an ok job of explaining it :(
  12. #8
    mark84's Avatar
    I was curious, is it possible to set the spindle speed on the vfd, and start it up, at least if I could do that I could do some milling without fear of another broken end mill!?
    The router has never had heavy usage, I can't reliably say total hours used, but it's likely a typical week it's in use an hour, over the past 3(??) Years.
  2. Replies: 5
    Last Post: 29-09-2014, 02:42 PM
  3. Replies: 0
    Last Post: 13-11-2013, 07:50 PM
  4. Spindle lock mechanism for 2.2kW china spindle
    By Jonathan in forum Generic Chinese Spindles
    Last Post: 13-08-2012, 08:39 PM
  5. DIY Spindle - What type of bearings are best suited for a spindle.
    By 8iggles in forum Spindles & Drive Motors
    Last Post: 09-02-2011, 10:15 PM
