Thread: Ballscrew Thickness!
Yeah, having two fixed ends does improve things - although on my machine it's one fixed (BK), and one floating (BF), and I would guess that's what the standard machining on Gary's ballscrews would provide.
I suppose you could use BK on both ends, but you'd need to make the ends with a lot of precision (or have a number of different size shims to pad out the end with the screw-thread).
18-08-2009 #2Visit Us: www.automationshop.co.uk
18-08-2009 #3
Waste of time on something like a router. You fit double thrusts on both ends, adjust to get a preload, and all that happens is the end frames deflect inwards so the screw is still whipping even with double bearings.
The design has to take this into account.
Bystronics have realised this on their new range of lasers, they have massive end castings and tension the ball screw to something like 70 tonnes tension [ no typo ] to stop it whipping.
Mind you they are using twin drives with 15 HP servo motors on each drive :whistling:
I feel the OP needs to sit down, count his pennies then come up with something that's workable instead of throwing down pie in the sky figures for his first build.
Why the insane rapids anyway ? The whole idea is to bury the tool and work at feed rate.
.John S -
Looking into a ballscrew, not sure if I should buy. Help
By oldmam4m80s in forum Lead Screws, Nuts & SupportsReplies: 21Last Post: 28-07-2017, 10:15 PM -
WANTED: Ballscrew and nut
By D-man in forum Items WantedReplies: 8Last Post: 30-08-2013, 04:25 AM -
Ballscrew Woes, help please!
By jonbabbz in forum Lead Screws, Nuts & SupportsReplies: 9Last Post: 21-04-2012, 12:16 AM -
Where to get C3 & C5 Ballscrew
By AdCNC in forum General DiscussionReplies: 10Last Post: 10-08-2011, 06:56 PM -
FOR SALE: Looking for a ballscrew (eBay)?
By Smiler in forum Items For SaleReplies: 13Last Post: 16-05-2009, 03:22 PM
