Thread: Ballscrew Thickness!
17-08-2009 #21
What height did you want to achieve from your Z-axis?
I personally think that a PM2278 driver would be a bit of an overkill for the Z-axis if you're using a NEMA23 for the stepper.
17-08-2009 #22
Roughly 7-8" the drive for the Z axis would remain the same as i have now! so looks like ill be selling 3 NEMA 23 425 oz-in steppers with 3 KL-4030 Drives rated at 3A if anyones intrested! Brand new!
Another thought was i could even go for a single NEMA 42 for the X axis and drive both of the ballscrews with a belt coupled together! what are your thoughts on this guys? the NEMA42 is rated at 2830 oz-in and can work at a max of 210v do you think this would work. ( im just trying save money as funds are abit low at the moment )Last edited by AdCNC; 17-08-2009 at 05:09 PM.
17-08-2009 #23
Yes the Z axis does not need to be as big, and the motor you currently have would most likely be ok, as you have it allready use it to see if you can get what you need, if not, then upgrade it.
does the Z need to be as quick? if not you could most likely get away with a 1605 ball screw.
Visit Us: www.automationshop.co.uk
17-08-2009 #24
hi gary, no the z can plod along at a nice steady speed really! its the x and y thats the main concern!
17-08-2009 #25
taking into consideration that the belt coupling could be 1:1 effectively each ballsecrew would see 1415 oz-in of torque thats not taking into consideration drive losses! thats if i used a monster 2830 oz-in stepper!
17-08-2009 #26
So are you going to use one motor for the X and two ball screws?
This can work well, but you need to take note that if the belt is quite long it can get a bit springy and you will see a bit of hysteresis.
I would personally use two motors and drivers.
A belt system can mean a loss of 10%.
17-08-2009 #27Visit Us: www.automationshop.co.uk
17-08-2009 #28
Another Idea. :whistling: Have you thought about fixing the ballscrew and spinning the ballnut instead?
You would reduce the amount of torque needed as the mass is reduced. I have one like this that I got from ebay.
Finally why do you need so much speed? Unless it has to return home after along cut, wont you be limited by the cutting speed anyway?
17-08-2009 #29Visit Us: www.automationshop.co.uk
17-08-2009 #30
options options options, think im going be scratching my head till ive build my machine and ready for the motion! and thats not to far away!
Looking into a ballscrew, not sure if I should buy. Help
By oldmam4m80s in forum Lead Screws, Nuts & SupportsReplies: 21Last Post: 28-07-2017, 10:15 PM -
WANTED: Ballscrew and nut
By D-man in forum Items WantedReplies: 8Last Post: 30-08-2013, 04:25 AM -
Ballscrew Woes, help please!
By jonbabbz in forum Lead Screws, Nuts & SupportsReplies: 9Last Post: 21-04-2012, 12:16 AM -
Where to get C3 & C5 Ballscrew
By AdCNC in forum General DiscussionReplies: 10Last Post: 10-08-2011, 06:56 PM -
FOR SALE: Looking for a ballscrew (eBay)?
By Smiler in forum Items For SaleReplies: 13Last Post: 16-05-2009, 03:22 PM
