Thread: Ballscrew Thickness!
16-08-2009 #5As Tribbles said the diameter required to reduce whip is fairly easy to work out. The pitch is not so. You mentioned speed and accuraccy..... I dont think the two are easily achived without lots of money.......Gary (from Zapp) gave me a website which allows you to calculate the whip speed based on the diameter and so forth
You havent said what you are cutting or what accuraccy you require. But if you are using steppers when 200 steps per rev at 5mm pitch gives 0.025mm resolution. With a 25mm pitch you get 0.125mm resolution.
Also given that for your 1829mm travel you will probably need 20mm + dia. then motor torque will be an issue, lots of mass and inetia to control.
I may be corrected by others but you are probably in Servo Motor terratory for the distances and speeds you require.
See the attached pdf that I got from Cnc-zone.( hope its ok to repost it. cant remember who its from. {Lee any probs just remove it}
Goes in to detail about designing motors, screws and feeds.Last edited by Ross77; 16-08-2009 at 01:22 AM. Reason: Bad speeelaing as usual
Looking into a ballscrew, not sure if I should buy. Help
By oldmam4m80s in forum Lead Screws, Nuts & SupportsReplies: 21Last Post: 28-07-2017, 10:15 PM -
WANTED: Ballscrew and nut
By D-man in forum Items WantedReplies: 8Last Post: 30-08-2013, 04:25 AM -
Ballscrew Woes, help please!
By jonbabbz in forum Lead Screws, Nuts & SupportsReplies: 9Last Post: 21-04-2012, 12:16 AM -
Where to get C3 & C5 Ballscrew
By AdCNC in forum General DiscussionReplies: 10Last Post: 10-08-2011, 06:56 PM -
FOR SALE: Looking for a ballscrew (eBay)?
By Smiler in forum Items For SaleReplies: 13Last Post: 16-05-2009, 03:22 PM
