Thread: conect 121 new toy
Thanks Nick, yes the base lathe is the ML10 but the electronics are Conect and there isn't much info about.
Ive seen reference to 10v control and an enable line for the spindle but not sure if I can run if direct off a BOB, or which wires they are.
08-09-2017 #2
My benchtop CNC mill was the same brand, most of the original electronics had already been replaced when I got it, I replaced what remained but I've never been able to find much info on Conect equipment beyond that the mill was probably based on a Rishton milling machine.
You should be able to identify the control signals with a meter and work out where to insert signals and at what voltages,
Regards,
NickYou think that's too expensive? You're not a Model Engineer are you? :D
08-09-2017 #3
From what I remember, you can trace the step/dir control pins back to the original controller chip.
However, they are 80s technology, and I don't think it would be worth the hassle. Even a couple of the TB6600 drives should give an improvement in performance, and they can be had for less than £10 each. Combine those with a cheap BOB, and you've got all the major components covered.
The only thing is you'd need to ensure the 0-10V for the spindle speed is isolated, or upgrade the spindle drive to something that doesn't need an isolated speed control.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
The Following User Says Thank You to m_c For This Useful Post:
08-09-2017 #4nothing works so I cant trace the signals.You should be able to identify the control signals with a meter and work out where to insert signals and at what voltages,
So if if i power the BOB from the 5v of the conect board will that not work?The only thing is you'd need to ensure the 0-10V for the spindle speed is isolated, or upgrade the spindle drive to something that doesn't need an isolated speed control.
Yes I will replace the stepper drivers but I would like to use the DC spindle motor?
08-09-2017 #5
As long as you can get the part number of the stepper chips, and find a datasheet, just trace the PCB tracks. Or there will only be 2 tracks that go to dedicated pins on the controller chip from each stepper chip, which leaves only two options as to what is the step and dir.
You really need to find out what the spindle drive is. Mine was a SCR style drive (very common for DC motors), which means the speed control terminals are at near mains voltage. Connect them to anything other than an isolated 0-10V, and something will be releasing magic smoke.So if if i power the BOB from the 5v of the conect board will that not work?
Yes I will replace the stepper drivers but I would like to use the DC spindle motor?Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
09-09-2017 #6Dam, I have no idea what drive it is. The machine is from 1986 and has the Lander control board. it does look like the input is 240v and there is a transformer before the motor.You really need to find out what the spindle drive is. Mine was a SCR style drive (very common for DC motors), which means the speed control terminals are at near mains voltage. Connect them to anything other than an isolated 0-10V, and something will be releasing magic smoke.
09-09-2017 #7
Post up some photos.
It won't be a transformer, it'll be a choke.
I know mine came with a Cheetah drive, but I had to replace it with a KBIC, as the Cheetah was blowing fuses.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
Conect 121 Retrofit
By Sooty in forum Lathes, Lathe Rebuilding & ConversionsReplies: 3Last Post: 17-02-2015, 11:45 PM -
Conect 121 DC spindle motor help!
By Sooty in forum Spindles & Drive MotorsReplies: 10Last Post: 05-02-2015, 03:31 PM -
FOR SALE: Conect 121 CNC Lathe
By m_c in forum Items For SaleReplies: 5Last Post: 27-03-2014, 10:44 PM -
conect 121 cnc
By minimad30 in forum Conect LathesReplies: 1Last Post: 31-07-2013, 11:07 PM -
More Conect Machinery
By leitzscope in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 09-04-2010, 10:09 PM
