08-09-2017 #1
Hi All,
Does anyone have experience using an 80mm Insert cutter to face off brass or Ali sheets. I'm trying to improve the finish and would appreciate input on feeds, speeds and strategies. Only removing between 50 and 150um. Milling Cutter has 6 inserts. Hurco i20 machine. 10000rpm spindle but don't run this tool above 4000rpm. Solid machine, decent torquey spindle
Cheers, PaulPaul Seddon
08-09-2017 #2
on our vmc's I would run that at 5000rpm and between 1000-1200mm/min
08-09-2017 #3
forgot to say make sure you are using polished aluminium grade tips
09-09-2017 #4
Thanks very much John. Will try on monday. Will let you know how I get on.
cheers, paulPaul Seddon
Face mill finish
By Edward in forum Tool & Tooling TechnologyReplies: 24Last Post: 05-02-2017, 02:08 PM -
Hypertherm plasma cutter advice.
By T0rnado69 in forum Plasma Table MachinesReplies: 11Last Post: 17-06-2016, 09:53 PM -
fly cutter advice please
By luke11cnc in forum Tool & Tooling TechnologyReplies: 13Last Post: 07-12-2014, 01:38 PM -
WANTED: Small pice of ali plate 80mm x 80mm x 17-20 mm
By charlieuk in forum Items WantedReplies: 2Last Post: 25-08-2014, 09:14 PM -
Front face DIY decals advice ..
By Fivetide in forum Metal Finishing TechniquesReplies: 9Last Post: 13-06-2013, 11:23 AM
