  1. #3
    Edward's Avatar
    Lives in London, United Kingdom. Last Activity: 4 Weeks Ago Has been a member for 9-10 years. Has a total post count of 113. Received thanks 3 times, giving thanks to others 0 times.
    I suppose it depends what you call the front or the back as you could operate the machine from the side. I don't see any difference where you mount the motor. Depending on the layout it could be mounted underneath the machine.
    Hi Clive,
    Quite true. You would also have to define which side, as there are 4 sides to a rectangle:) By the "rear" I mean the side behind the gantry (behind the spindle), although that could also be misinterpreted, if you want to be precise.
    Ok, semantics apart, by placing the pulleys at the rear and having the front clear, the front plate, if suitably designed, could occasionally be used to clamp a long piece when you needed to drill for side tapping, as an example. Provided the spindle reaches (overhangs) that far.
    On the other hand, with pulleys at the back, access for tensioning may be more difficult, depending on how you place you router, for instance, if the back is against the wall.
    Other than these considerations, I can't think of anything else.
    Edward
  1. RFQ: Motorcycle rear reservoir bracket x1 (CAD files ready)
    By stuartpurdue in forum Projects, Jobs & Requests
    Last Post: 11-01-2016, 12:08 AM
  2. RFQ: RFQ. I am looking for 2 bicycle rear dropouts to be made in Aluminium
    By aideym in forum Projects, Jobs & Requests
    Last Post: 25-11-2015, 10:45 PM
  3. WANTED: Boxford TCL 160 front panel
    By Saracen in forum Items Wanted
    Last Post: 07-11-2014, 01:14 AM
  4. Front face DIY decals advice ..
    By Fivetide in forum Metal Finishing Techniques
    Last Post: 13-06-2013, 11:23 AM
  5. RFQ: Z axis front plate
    By Shinobiwan in forum Projects, Jobs & Requests
    Last Post: 11-11-2012, 12:41 AM
