It's a bugger.
So, it used to work, but is now intermittent? So something has changed.
Thoughts:
Dry-joint and thermal expansion causing the joint to break when the microcontroller starts to warm up. Reasonably possible - examine the SMD device under magnification; if you're handy with an iron (and have a reasonable good iron) then a splash of flux across the SMD pins and walk a ball of solder over the pins and clean-up with desolder wick/braid then clean the board with IPA etc.
or...
Another person had a problem with a failed crystal - a 16Mhz crystal costs pennies and is a 10 minute job to replace. It could be that it's failing under vibration of the printing.
or...
Power Supply failure?, might be worth scoping/triggering on the supply level dipping a bit. More unlikely than the above, and would need a scope to fault-find. Could be caused by a faulty stepper driver drawing too much current.
(that's a thought - can you drive each axis to see if any one is causing problems?)
Have a look at the caps around the switched-mode PSU - any sign of leakage or bulging - worth replacing (you could be getting spikes on the logic supply).
Other noise?, that micro is likely all configured for I/O with only the supply lines and reset lines likely to cause problems.
Actually, could you swap the drivers around?, see if the problem follows a driver?
You mention conductive crap... possible, and there's nothing wrong with a bit of compressed air (just don't poke it down the buzzer). But definitely worth an inspection under magnification.
AvE (youtube) has a plausible theory that thermal issues account for the majority of problems - have a poke around with a finger whilst the printer is running - anything getting hot?
Basically... lots of things to look at and definitely worth spending 30 minutes really going over the board.It's a low density board, quite workable, but much depends on your dedication to not spending money (I'd have a bloody good go at it before forking out £150)
30-10-2017 #2
Thanks Doddy,
Before I get too involved, I have a couple of things to try. I always print using the SD card and a faulty reader could be the cause, so first I am going to try printing via the USB link. Also I will get a new card reader from Wanhao UK on a return basis. If no difference, it can go back. The same for the mainboard, but I may end up sending that to them to check out in another 4DS machine
Sticking a finger on components is difficult as they are all under the main deck and difficult to access when the machine is running.
I thought about the PSU glitching, it is a 24v SMPS unit, so I might just put some sort of voltage drop detector on it using my little scope, but that would be a pain and so is down the list.
Likely suspect is the card reader or the cable from the reader to the mainboard, I had trouble with it before as it got sh1t in it, so maybe the pins are messed up.
I haven't got £150 to shell out on an off chance anyway, so I would have to be damn sure first.
Cheers,
Rob
30-10-2017 #3
Certainly worth trying the easier things first.
I think yours is similar to mine (a Qidi - looks externally very similar, I've had it apart in the past but can't remember the board) - certainly appreciate it's awkward to get to - but set it on a couple of blocks with the bottom off, you can poke a digit or two.
The SMPS - I was actually looking at the SM regulator on the corner of the card - that'll drop the 24V to 5V for the logic, that's the one I'd scope.
Ironically, my previous 3D printers (a RepRap) - it was the USB that was the weak point with ground loops/noise and the card reader more robust (until I tripped over the cable and yanked the micro USB connector off the main board and replaced with a BlueTooth UART, which solved all the problems).
31-10-2017 #4
I have just ordered a new card reader. I will see if that sorts it out later in the week. Connecting via USB is a PITA, getting the coms driver working is not for the faint hearted.
I think I am going to forget the 3D printer for a day or two and cut some ali on my router. If that doesn't bugger me about !!!
BobCAD v24 is there anything better for £150? Any help will be great thanks
By suesi34e in forum CAD & CAM SoftwareReplies: 17Last Post: 21-05-2015, 01:48 PM -
EXPERIENCE: Routout CNC - Brilliant Customer Service and Product
By magicniner in forum Trading Experience & FeedbackReplies: 0Last Post: 21-03-2014, 11:27 AM -
More great help wanted please from the wise!
By suesi34e in forum General DiscussionReplies: 7Last Post: 13-01-2014, 02:19 PM -
Chinese customer support
By wiatroda in forum General DiscussionReplies: 2Last Post: 19-08-2011, 08:45 PM -
Some great DIY clamping setups
By Yohudi in forum Computer SoftwareReplies: 2Last Post: 22-01-2009, 06:54 PM
