Thread: Cnc machinations from Hampshire
Hi all
Been playing with an old Clarke cmd1225 mill that someone had started to add cnc to. It worked but was very basic plus the pirated mach3 wasn't up to much. Anyway, I added limit switches and a host of other little tweaks plus started to learn fusion 360 then bought a mach3 license. I then had to install the latest version and whilst I thought I had the settings backed up apparently I hadn't. Oops! This led to a lot of setup learning but eventually I got it running enough to try cutting some ally. I tentatively lowered the cut whilst watching carefully and all was well until it took a bite through the stock that was a chip too far. I got to the emergency stop as the motor stalled - phew. I now have a patented cutter that cuts round corners, ok, just a bent cutter to you and I.
Problem is, seems I caught a bug. I collected a Boxford 250pc and 300 vmc at the weekend. Wow, these things are big and very heavy. Getting them home is another story suffice to say I now know what an exploding castor wheel sounds like. Neither have a pc so the aim is to mach3 both
Good old winter projects. More posts soon hopefully.
Does anyone have any experience with either of these boxford machines and mach3?
Ian
Sent from my SM-G955F using Tapatalk
10-02-2019 #2
Hi Ian
I have just bought a cmd1225 to convert into a cnc machine, any tips or photos of yours? what did you do for the Z axis? are you running ballscrews or the ACME screws? and if Ball Screws did you do a conversion?
Any photos or tips would be welcome.
Kind regards
Simon
15-02-2019 #3
Hi Simon,
Just to let you know Ian's emails from the forum are bouncing back to the server, so at the moment he won't be getting any notifications and replies to this thread.
Nothing more I can do unfortunately as I've got no way to make contact with him to let him know, he's also not been active since about June last year.Lee
NEW MEMBER: Hello from Waterlooville, Hampshire
By Chester in forum New Member IntroductionsReplies: 16Last Post: 18-02-2018, 09:06 PM -
NEW MEMBER: Hello from Hampshire
By gr8fun in forum New Member IntroductionsReplies: 5Last Post: 28-11-2012, 08:42 PM -
NEW MEMBER: Hi from Hampshire
By LotusPack in forum New Member IntroductionsReplies: 1Last Post: 01-05-2012, 11:04 PM -
NEW MEMBER: New member - Hampshire
By Briann in forum New Member IntroductionsReplies: 1Last Post: 28-01-2011, 10:19 AM -
By Andrew_Standen in forum New Member IntroductionsReplies: 4Last Post: 20-09-2010, 09:11 PM
