Thread: Best anodizing guide?
02-10-2017 #2
The specific heat capacity of water is 4.184 joules/gram/deg, so to raise 5 litres of water from 20 to 80 degC, would take 1255200 joules (4.184 * 5000 * (80-20)), or 0.349 KWh. Now if you've only got 120W, that means it would take 2.91 hours (0.349 / 0.12) assuming you have zero heat loss.
However, unless you've got insulated containers, I'd doubt you'd ever get to 80degC.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
02-10-2017 #3
Pretty much spot on. Tried it for the hell of it and got the top third of the water to 50c/
The rest stayed at 16c (workshop room temp). That was nearly 1 hour.
I am thinking 1000w min really as I don't want to wait too long for it and once one puts the part into the bucket the temp will go down quite a bit. So need it to be fast enough to recover from that.
Wondering if something like this would work?
https://www.aliexpress.com/item/900W...809794841.html
Keeping in mind a 5L bucket is around 200-220mm tall?
Not sure if these are designed for water but should be okay as long as the top is kept above water line I believe.
02-10-2017 #4
With something like that, I'd be making sure they were well earthed, and powered via a good RCD.
Have you had a look at any of the youtube videos for ideas?
I've got these saved in my watch later list
https://www.youtube.com/watch?v=BtYHcsq7s5A
https://www.youtube.com/watch?v=GccTVfMiIIo
https://www.youtube.com/watch?v=TGi-nqNnENE
It's been a while since I watched them, so can't remember exactly what they covered, but they must of contained something worthwhile that I never deleted them after watching them..Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
The Following User Says Thank You to m_c For This Useful Post:
03-10-2017 #5
Thinking about it.
Cleaner, Dye and Sealer don't care if they are in a metal container?
Why not just use stainless cooking pots and put them on those cheap hot plates?
http://www.ebay.co.uk/itm/Single-Ele...EAAOSw-K9ZIxN4
As variable knob too so could potentially not even need thermostat controller?
Obviously not put the acid/lye in these, they still need plastic containers.Last edited by JOGARA; 03-10-2017 at 02:28 PM.
03-10-2017 #6
that's probably the way i'd do it personally yeah
The Following User Says Thank You to Zeeflyboy For This Useful Post:
03-10-2017 #7
Yet Another Noob. Looking for Kit or Guide
By RatherBeMaking in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 09-04-2015, 09:52 AM -
Idiot's guide to Dolphin?
By m_c in forum DolphinReplies: 7Last Post: 18-12-2013, 02:42 PM -
DIY CNC Safety Guide
By tati in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 12-08-2013, 12:02 PM -
First Experiments Anodizing Aluminium at Home
By h4ppy-chris in forum Metal Finishing TechniquesReplies: 11Last Post: 13-02-2011, 01:10 PM -
SMD-How to guide?
By Ross77 in forum General ElectronicsReplies: 12Last Post: 17-08-2009, 06:43 PM
