Thread: carving issues-UNSOLVED
10-10-2017 #11
(probably why it doesnt work lol)
Ya could be right there, start with contacting Rhonmac.
Phill
10-10-2017 #12
do you use Aspire yourself Phill? if you do would it be possible please for you to output me a simple file 100mm X 100mm project size and a pocket of 60mm X 60mm depth of 30mm tool size 8mm mill, that way I will be able to check if my software is working correctly. Thanks not to worry if you cant or dont use.
10-10-2017 #13
Yes mate on it now
10-10-2017 #14
awesome thank you
10-10-2017 #15
cheers Phill will let you know tomorrow
The Following User Says Thank You to woodworker For This Useful Post:
11-10-2017 #16
Hi Phill
Same unfortunately the tap file cut ok for around 5 cuts then went left by approx 20mm (the bit doesn't like being shoved across a thick piece of wood) and the second file cut to the right approx the same at least I can rule out Aspire as the culprit, going to make a phone call me thinks.
11-10-2017 #17
Solved turns out my Mach 3 copy is corrupt what did I expect as it came with my long dead Chinese laser machine so I now need to purchase a new Mach 3. Big thanks to Phill for going beyond the call really helped me nail down the issue.
11-10-2017 #18
If you purchased a proper licence, then you should be able to download Mach3 and use the same licence. If the licence came with the Chinese laser, then it is probably a 'pirate' and the download won't work with it.
11-10-2017 #19
yeah should have realised :) reg to papa somebody just have to wait for payday now.
11-10-2017 #20
papa fabio strikes again.
Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
3d carving oak
By Mikeb in forum Woodwork DiscussionReplies: 11Last Post: 24-03-2014, 10:22 AM -
V bit carving
By Mikeb in forum Tool & Tooling TechnologyReplies: 4Last Post: 20-02-2014, 04:52 PM -
tools for 3d wood carving
By chris in forum Marketplace DiscussionReplies: 5Last Post: 18-01-2014, 04:23 AM -
3d carving bits
By drut in forum Tool & Tooling TechnologyReplies: 9Last Post: 04-07-2013, 01:03 AM -
Microcarve picture carving software
By cnctoybox in forum CAD & CAM SoftwareReplies: 0Last Post: 26-03-2012, 07:00 PM
