Thread: carving issues-UNSOLVED
13-10-2017 #31
Think I will get murdered by the Mrs if I skipped it lol, the control box is a Rhonmac not sure on controller cards etc all in a nice neat box, I have noticed that when I jog the motors usually first thing they just make a noise and dont move obviously if this happens mid cut it would cause my issue, but so far I have been unable to hear the noise when its all running. I'm wondering if its to do with the speed I have it set to?!!
not really sure if the settings are correct my machine info is 1600 steps 8 micro steps 15 motor teeth leadscrew 30 leadscrew pitch 2mm expect this means something to somebody. Mach 3 is set to steps per 2000 velocity 438 acceleration 187.5Last edited by woodworker; 13-10-2017 at 07:50 PM.
13-10-2017 #32
It could be a motor stall problem. Try reducing the acceleration, you can always set it back up if no difference. Your Mach3 steps per looks wrong. I am very tired at the moment, so if anyone would care to check my calcs please let me know if I am out.
Motor has 15 tooth pulley, Leadscrew has 30 tooth pulley (I would have expected this to be the other way round - but no matter)
2:1 pulley reduction
2mm pitch leadscrew means axis moves 1 mm per revolution of the stepper, ie 200 steps, 8 microsteps means 1600 pulses per rev, i.e. mm.
So steps per in Mach3 should be 1600 not 2000.
Have you done any dimension tests yet or has your current problem overshadowed things ?
14-10-2017 #33
Thanks Cropwell I have a pile of firewood so far I will PM my number I wasnt around earlier but in all day tomorrow if you have time. The 1600 looked obvious when I typed it duh just seem to be going round in circles, not 100% sure about dimension tests but I cut some pockets and found them to be several mm out.
14-10-2017 #34
I did mention all this to you in post #7 when I checked your code. (I see that you have deleted the code).
So do as Rob says and lower the acc. at least on the axis that is stalling...Clive
14-10-2017 #35
Right guys tried setting up the machine with the set steps in settings it failed twice to move the x axis and once on the z I tried again success on the next attempts all ok with distance, it has probably failed to move at least 10 times this morning at various settings (all on the jog buttons mostly x axis). so I set up a couple of dry run pockets without extraction and router so I could hear any motor changes on the second cut I heard one at a about 30 % in I am thinking this must controller related now I will post up what they are once I've got the screw driver out.
14-10-2017 #36
Look like your amps are set to 4.5 try dropping to 3.7 that is sw1-off sw2-on sw3-off then retry
Phill
14-10-2017 #38
14-10-2017 #39
I'm confused I have a piece of paper (came with the machine) written on the back in pencil are the dip switches, looks like they are all wrong paper says
123 off =1.5a with a tick next to it
sw4 = on Half current
Micro step 5678
5=off
6=off
7=on
8=off
to me it looks completely transposed could this be it....
I might be wrong but I think it should be sw1-off sw2-on sw3-off = 3.7 amps, 5=on 6=on 7=off 8=on that's 1/8th micro
3d carving oak
By Mikeb in forum Woodwork DiscussionReplies: 11Last Post: 24-03-2014, 10:22 AM -
V bit carving
By Mikeb in forum Tool & Tooling TechnologyReplies: 4Last Post: 20-02-2014, 04:52 PM -
tools for 3d wood carving
By chris in forum Marketplace DiscussionReplies: 5Last Post: 18-01-2014, 04:23 AM -
3d carving bits
By drut in forum Tool & Tooling TechnologyReplies: 9Last Post: 04-07-2013, 01:03 AM -
Microcarve picture carving software
By cnctoybox in forum CAD & CAM SoftwareReplies: 0Last Post: 26-03-2012, 07:00 PM
