    You have the user name "Schematicsman", you are going to mill a pcb, and yet you can't wire two switches in series ? plus you can't read the previous two posts ! having a laugh ?
    version 2 of limit switch diagram
Name:	limit switch connections v2.jpg
    John
    PS
    Hi john I would like to know How to wire 2 limits so when either one
    Is pressed that axis stopes??? Which one Normally Opened
    or Normaly Closed??? Can I use the ground from the pic I upload of my board that has that single black
    Wire ??? Or does it need to come from what you have on your drawing???
    Quote Originally Posted by Schematicsman View Post
    If you are daisy chaining your switches together, ie connecting them in series then they need to be normally closed.
    If you look at John's post #11 he shows you the limit switch cables.
    as Clive said
    wire N/C switches in series
    it should be the safer option as the machine will stop if a wire breaks
    as this is more likely than a two core cable being short circuited
    (although it could happen if a cable is crushed)
    the last diagram of post 11 is for 1 axis ,
    you will need three pairs of N/C switches for the 3 axis
    as mach 3 only homes 1 axis at a time you could connect all 6 switches in series and use just 1 input
    John
    Hi there John but your drawing has com and NO pin connected and mine is NC and COM pin on mini limit switches...
    check my pic of 2 switches for one axis in series connected and tell me if I have wired it correctly???Click image for larger version.
    Then which one of the COM or NC(NO) is GND or +5V and which one signal???
    also Can I use all ground connections from that free connector on the right side of the board near 24V that says::--->> C NO 0-10V GND-<<<---?????
ID:	22906 on this pic??????
    I'm confused
    Where does it say that John shows com and NO? Do you have a multi meter? I suggest you read the post again. As the drawing clearly shows you the way it is wired.
    With a multi meter is is very easy to check you have it OK. You can also check if the two grounds ie the 5V one and the one you referred to are indeed connected together. If you are not sure use the 5v ground
    hi there John for starters that is just a user name i came up with, has nothing to do with anything and im a newbie in all of this wiring and cnc stuff.so im trying to learn how to wire everything up and properly setup Mach 3 like everybody else to start doing some milling ect.and I need to know,do i need to use resisters and also how do I wire all coms together and fit the wires in the connector???? :(
    Hi Schematicsman
    if you have the jumper J1 set for using the boards +5V supply
    you don't need to add any resistors - that's why I removed them from the original diagram
    as to how you physically wire the switches it depends on what connectors you have fitted to the control box
    very often you find "aviation" connectors are used on Chinese control boxes
    the boxes having a number of holes for 4 limit switches and a probe
    blanked off by a paper label when the connectors have not been installed
    a photo of your box will help
    if you fit four 2 pin connectors
    then one pin on each connector is connected to the common ground
    then printer port pins 10 ,11, 12, 13 can be connected to the remaining connector terminals
    pin 15 can go to your E-stop switch
    I will add more later when I return home
    John
    PS
    this is the typical connectors found on Chinese control boxes
    note – the danger of mains voltage on chassis mounting plugs !!!
Name:	control box connectors.jpg
    from other posts
    some other DIY options that have been used are
    either pass the limit switch cable through a strain relief or
    used a terminal block fastened to the box
Name:	control box limit switch terminal block.jpg
    once I know what you have and what method you want to use
    either wire the limit switches directly to the breakout board or go via connectors mounted on the box
    I will add more diagrams of the wiring
    PPS
Name:	limit switch wiring.jpg
  1. Limit switch problem
    By ECCO in forum General Electronics
    Last Post: 25-12-2015, 11:28 AM
  2. Limit Switch wiring question
    Last Post: 03-06-2015, 02:11 PM
  3. One limit switch per axis
  4. Limit switch wiring question ...
    Last Post: 31-10-2010, 11:06 AM
  5. Limit switch's - best configuration?
    By HiltonSteve in forum General Electronics
    Last Post: 13-08-2009, 01:26 PM
